3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8x8 LED Matrix Animations
  • last photo ←
For a party we were about to have I wanted a cool light display to use with my new Xmas present  - an Arduino Uno. Having looked at the LED matrix's here I wanted a bigger one that  I could hang on the balcony.
I also wanted it to interact with music and flash at different sound levels and have a keypad to select which animation to run.
Thus I came up with this one using some spare  Xmas lights I had already butchered for some outside art projects. I also wanted it to look arty, hence the use of copper wire for inside the frame.
Before we start on the construction I will go through some of the theory behind the matrix.
Please Note : I didn't use resistors between the matrix connecting wires and the Arduino. You should really use them to limit the current to the LED's and also avoid damaging the Arduino. If you don't use them then that's at your own risk
Step 1Materials Required
Materials Required
As stated this is a 8x8 matrix so you will need 64 LEDS. I had some spare 25 LED xmas light strings, so I used these as my source for the LEDS.
Timber for making the frame.  This frame used approx 3.6m of 45mmx18mm of timber.
Arduino Uno
Power Supply (I used a 9v battery)
Copper Wire for the wiring inside the frame. This copper wire has a coating on it which is not conductive so is ideal for this. The type used in motor windings is ideal. I got this from the local metal scrapman.  Need about 19m of this. The thicker the wire the better.
Cat 5 (network) cabling so the matrix pins can be connected to the microcontroller.
Screws and/or wood glue to build the frame.
Keypad, Microphone, Resistors, Capacitor's and op-amps required for the hardware add-ons. Please see those steps for the links to the other instructables that list the required components.
Tools Required
Saw for cutting the timber
Staple gun for attaching the copper wire to the frame
Soldering Iron and solder
Multimeter
Pliers
Electric Drill + drill bits
Computer to program the Arduino along with the correct USB cable.
Sharp knife - Stanley knife or similar.
28 comments
Aug 28, 2011. 5:20 PMtriodo says:
se ve cheverisimo los led
Jul 4, 2011. 9:11 PMfostersfriend says:
You should really use hex code saves alot of memory
May 24, 2011. 11:18 AMarodri35 says:
I'm curious on how you managed to drive that mmany leds with the current limit on the arduino. I'm trying to drive 25 in the same way.
May 25, 2011. 1:38 PMarodri35 says:
also, would it be smart to use a 2n222 npn transistor at each pin ????
May 25, 2011. 11:37 AMarodri35 says:
haha i feel dumb i knew that. where exactly would you place the resistors. would you give each led its own or would you just put it right before the pin. so in the test leds file you turn them on and off rapidly?
May 25, 2011. 5:32 PMarodri35 says:
oh ok i just figured it might make it a little less current for the arduino, i've heard they're not very fond of current, going in or out so i thought that could be used as a precaution. as far as the resistors go thanks i thought that's how it was supposed to go thanks for the help. im making what essentially might be a touch screen using the arduino capsense and your matrix. if the capsense doesn't go well ill just make it a mini display haha thanks again
May 1, 2011. 10:11 PMphanna says:
Excuse me! could you tell me what components that you use in this project? and what program you generate this code?
Apr 6, 2011. 10:39 AMjschuster says:
I try uploading the test code to my uno and i get
Binary sketch size: 1178 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I have loaded the Arduino environment and I'm not sure what id doing wrong. Do you have any suggestions
Mar 23, 2011. 5:13 PMjschuster says:
Do you have to go to the strip board or can you go straight to the arduino?
Feb 20, 2011. 6:40 PMjdanderson1 says:
when you build this check the programming it uses A0, A3,A4,A5 in the Arduino program. The instructions don't reflect this they use different address lines so if you have a problem check your outputs.
Otherwise i really like this still in the process of building one.
Feb 6, 2011. 3:39 PMraikoug says:
Hi, i really love your work, and I thank you very much.. but.. (maybe is a n00b question) the copper wire... doesn't touch each other right? do you use the cover of the wire led to separate the crossing? that's amazing if i'm right (you see? this is a very noob question becouse i shiould really know if + and - should touch each other, and I'm pretty sure they don't have to, but maybe ... dunno :P)
thanks anyway for the big work ^^
Feb 7, 2011. 12:02 AMraikoug says:
Oh... that's funny.. thanks a lot!!
Feb 6, 2011. 5:49 PMbluumax says:
Great job!!
If you can PWM the outputs you can do without resistors.
I used wrapping wire for a tiny Christmas tree project using 0603 size LEDs. & a PIC http://www.bluumax.com/Tree.html
It's kind of a trick for electronics people, how do you get + & - with only bare wire?
Feb 6, 2011. 7:41 AMmal511 says:
I think the expression "nit picking" is appropriate, don't you tigerbomb8..?
Feb 4, 2011. 1:35 AMBWChronos says:
Awesome LED matrix, but you couldn't have asked your mom to move for like five minutes when you filmed this?
In all seriousness: this is awesome man, keep up the good work!
Feb 3, 2011. 6:08 PMmember02 says:
I see no current limiting resistors. To prevent damage to the arduino/LEDs you should add resistors.
take note, V=IR, Volts=Amps*Resistance
so blue LEDs have about 3-3.2 voltage drop across them, the arduino sends them 5volts. to achieve a 3.2v connection to the LED you need a 100ohm resistor in series with the LED. See, LEDs at 5v will try to draw well over 80mA, chances are the arduino can't supply much more than 50mA per pin, as per their spec sheet. This obviously causes stress on the system you have.
I normally don't care to help people that make this routine mistake, but this was featured and it is nice looking, so fix it!
Feb 3, 2011. 11:50 AMomnibot says:
Sweet! That's some LED-display. Any ideas for implementing a frequency analyzer och similar?
Feb 3, 2011. 12:33 PMmrtimklein says:
Love it. I'm working on a similar project -- wearable light show for a "techno" dance. I'm struggling with software, have you made any progress on mic input and possibly even beat detection?
Feb 3, 2011. 3:23 PMshabaki says:
while i understand it would take just over 512 leds it would be amazing to make an 8 by 8 cube and rig it up to some overly complex ai system with interactive sensors ( such as voice sensors or stuff like light sensors) and program it so the ai had an avatar "head that floated in the cube with different expression based on "emotions" in its coding so that you had a fully functioning ai bot; rig it to your comp, tv or entertainment system and you have a diy jarvis from iron man :P
Feb 3, 2011. 3:06 PMtigerbomb8 says:
leds are basically diodes
wrong leds ARE diodes
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:ndsit(Cake it Or Leave It)
