3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8x8 LED Array Multiplexed Infinity Mirror
A little bit different than your regular Infinity Mirror. Using a piece of mirrored acrylic for the back mirror, 8 rows of 8 holes are drilled into in a grid pattern. A LED is then placed in each hole and wired up so that i can be multiplexed through a controller.
The frame I built for this project is very similar to my 8x8 Infinity Mirror, but instead of having glass for the rear mirror, I used mirrored acrylic which is easily drilled. And there are no LEDS around the outside. All the LEDs are in the back mirror and appear to be floating within it.
I got the idea after making an octagon mirror with a inner ring of LEDs, the effect of the LEDs floating in there is quite appealing, so I decided to do a small/simple project to demonstrate.
Building the actual frame will not be covered in detail here, but plans are in the ZIP. For detailed instructions on building the frame please see my other Instructable - 32 LED Infinity Mirror
The firmware is written in C18 for the PIC18F1320 and the TPIC6C596 high power shift register. Its a very basic program, with just 4 patterns to display, 2 switches change the pattern and the speed.
UPDATE: Kits are now available for this project, the LED controller is not being offered, but there are many different 8x8 array controllers out there to choose from. Quality glass 2-way mirror on the front and mirrored acrylic for the back, drilled and ready to use. Link
Check Out my Infinity Mirror Gallery
Step 1Supplies
Get a Kit including the Frame Parts, front and back mirror, drilled and ready. LED Controller is not being offered.
Electronics:
- PIC18F1320
- 18pin socket
- TPIC6C596 shift register
- 16 pin socket
- x64 5mm LEDs, whatever color, I used white. Buy Some
- x3 10kohm 1/4w resistors
- x8 220 ohm resistors, may be different based on color
    *Used high value resistors because they LEDs shouldn't be to bright inside an infinity mirror or it won't        work as well.
- 1 uF capacitor
- 0.1uF capacitor
- x2 momentary pushbuttons
- 5v @ ~1A power supply with DC Jack Get One
Circuit Board:
- Solid strand wire
- Perfboard
Frame:
- Plans are on the next page or in my 32 LED Infinity Mirror
- I use 100mil Polystyrene, but acrylic or 1/8th masonite would work as well
Tools:
- Soldering Iron
- Hotglue gun
- drill and bits, for button hole
- 5mm drill bit for LEDs
- Utility Knife
I could put a kit together for everything or just certain parts, Contact Me to find out
9 comments
Oct 26, 2011. 9:18 AMiljx985 says:
Hye! is it possible tho make a infinity mirror with a non flat surface?
could a front car window to the trick?
Jun 4, 2011. 9:31 AMarbita2 says:
good
Mar 17, 2011. 6:14 PMMillchard says:
Great stuff ...thanks for your work. Would you be able to re-submit the schematic showing the placement of the 2 capacitors? Cheers
Mar 15, 2011. 9:15 PMmfenner-1 says:
this is probably a silly question. but where is the best place to buy acrylic? i am just after normal acrylic not a mirrored one
Feb 6, 2011. 4:40 PMashscott says:
Cool! I love to have one of those!
scottsdale dentist
Philwebservices
Feb 6, 2011. 11:12 AMClayfig says:
This is sweet!! you put kits together too!? awesome =]
Feb 5, 2011. 5:11 PMTOCO says:
cool, I have seen huge versions of these at museums. I was wondering how they worked. Ever since I saw one in a museum I wanted a smaller one for my house.
Feb 4, 2011. 10:34 AMDr. Pepper says:
Sweet!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
