Update 25.09.10
I've added a pattern generator to create patterns but not all of it's features are complete
Remove these ads by
Signing UpStep 1Materials
-8x8LED matris (can make one but i bought mine)
-16x120Ohm resistors
-8xNPN transistors (I used C547B)
-1xPIC16f690
-prototype board (or you can make pcb for this)
-wire
-5V power supply (you can use a voltige regulator but I just power mine from a usb port)
Tools:
-PIC programmers (all the pic programmers from microchip exept for pickit1 will work)
-Software- MPLAB (free software from microchip)
-Soldering iron
-A vacum pump for removing solder is good to have
-wire cutters
Skills you need:
-soldering skill (being capable of making good solder connections within 5-10 sec.)
-Logic thinking to some level
If this is your first experiense using microcontrollers I recommend that you start with a more simple project.
Thanks
I have a simple ASM program with a matrix display light just columns. An example:
LIST P=16F876
#include <p16F876.inc>
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
ORG 0x2100
DE 0x00
ORG 0
cblock 0x20
d1
d2
d3
endc
goto start
Delay
;999990 cycles
movlw 0x07
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;6 cycles
goto $+1
goto $+1
goto $+1
;4 cycles (including call)
return
loop:
movlw b'00000111'
movwf PORTA
movlw b'11110010'
movwf PORTB
movlw b'11111111'
movwf PORTC
call Delay
call Delay
call Delay
goto loop
start:
bsf STATUS,RP0 ; select register page 1
movlw 0 ; put 0 into W
movwf TRISC ; set portC all output
clrf TRISA
clrf TRISB
bsf STATUS,RP1 ; select Page 2,
bcf STATUS,RP0 ; by setting RP1 in Status register and clearing RP0
clrf PORTC ; select Digital I/O on port C
bcf STATUS,RP1 ; back to Register Page 0
goto loop
end
This program code is OK. But I want the program to which I could display the words fleeing across the screen. Started, I tried to ignite a pair of columns on different sites but with the burning LEDs. But received some strange flashing, do not light longer ... Anybody know what's wrong ...
Programme code:
LIST P=16F876
ORG 0x2100
DE 0x00
ORG 0
cblock 0x20
Delay1 ; delay loop 1
Delay2 ; delay loop 2
Delay3 ; delay loop 3
TimeDelay ; time delay x 0.001 s
EndCount ; used to tell PIC the end of the table is reached
Counter ; used as table counter
Line1 ; Line 1
Line2 ; Line 2
Line3 ; Line 3
Line4 ; Line 4
Line5 ; Line 5
sad
Line6 ; Line 6
Line7 ; Line 7
Line8 ; Line 8
Layer4 ; brightness, and time
Brightness ; LED brightness
Time ; time for each pattern to stay
Temp ; temp register
d1
d2
d3
endc
goto start
Delay
;999990 cycles
movlw 0x17
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;6 cycles
goto $+1
goto $+1
goto $+1
return
loop:
movlw b'00000001'
movwf Line1
movlw b'11110010'
movwf Line2
call output
call Delay
movlw b'11100000'
movwf Line1
movlw b'10101010'
movwf Line2
call output
call Delay
goto loop
start:
clrf TRISA
clrf TRISB
goto loop
output:
movfw Layer4
andlw b'00000001'
movwf Time
incf Time,1
bcf STATUS,C
rlf Time,1
bcf STATUS,C
rlf Time,1
bcf STATUS,C
rlf Time,1
bcf STATUS,C
rlf Time,1
bcf STATUS,C
rlf Time,1
clrf PORTB ; clear port B
movfw Line1 ; move layer1 to W
movwf PORTC ; put W onto PortC
bsf PORTB,4 ; turn on layer 1 buy outputing bit 5 of PortB
movfw Brightness ; put brightness into W
call Delayy ; call the delay
bcf PORTB,4 ; turn off layer 1
movfw Brightness ; put Brightness into W
sublw 4 ; sub W from 4
btfss STATUS,Z ; skip if the zero flag is set
decfsz Time
movfw Line2 ; move Line2 to W
bsf PORTB,5 ; turn on layer 2 buy outputing bit 6 of PortB
bcf PORTB,5 ; turn off layer 2
decfsz Time
decfsz Time ; decrement the Time regiester
return
Delayy:
movwf Delay3 ; put W into Delay 3
Loop1:
; After Delay2 decreses to 0, it is reset to..
movlw 0x1 ; put 1 into W
movwf Delay2 ; put W into Delay2
Loop2:
; After Delay1 decreses to 0, it is reset to E9h
movlw 0x1D ; put 80 into W
movwf Delay1 ; put W into Delay1
Loop3:
decfsz Delay1 ; decrement Delay1
goto Loop3 ; jump back to Loop3
decfsz Delay2 ; decrement Delay2
goto Loop2 ; jump back to Loop2
decfsz Delay3 ; decrement Delay3
goto Loop1 ; jump back to Loop1
return
end
Thanks for help. :)
goto $+1
goto $+1
goto $+1
what does $ mean?
Delayy:
that your subroutine is called but you call Delay on some parts of your code
The other part of your problem might be that you clear PORTB in the call of outputs
The code does not put PORTC all to 0 before it starts outputting so that might be a part of your problem
If it´s neither of those then I'm not sure what's wrong
output:
bcf PORTB,4
movfw Line2
movwf PORTC
bsf PORTB,5
movfw Brightness
call Delay ; call the delay
bcf PORTB,5 ; turn off layer 1
this code show indisplays line2 to spend line1. I want to display the line1 and line2 in one time. How to change the code?
this is coded with assembler code
http://www.mstracey.btinternet.co.uk/pictutorial/picmain.htm
this is a good learning tool (althoug i'd like to point out that i don't know how to write a program from scratch i am capable of modifying programs alredy written)
and a good way to start is to actually understand what each command does (althoug he post it in hex format and i use text format for the commands)
movlw is moving some value into the register W for example
movlw b'10000000'
now the binary number 10000000 is in the w register
to move something from the W register into another name for example name_1
movlw b'10000000'
movwf name_1
here is a code that i put together for you to make a LED blink (uses PORTC 0 as output)
;Code starts
#include
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
; Delay = 1 seconds
; Clock frequency = 4 MHz
; Actual delay = 1 seconds = 1000000 cycles
; Error = 0 %
cblock 0x20
d1
d2
d3
endc
goto start
Delay
;999990 cycles
movlw 0x07
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;6 cycles
goto $+1
goto $+1
goto $+1
return
loop:
movlw b'1'
movwf PORTC
call Delay
movlw b'0'
movwf PORTC
call Delay
goto loop
start:
clrf ANSEL ; select Digital I/O on port C
clrf ANSELH ; " "
goto loop
end
;Code ends
http://www.sure-electronics.net/DC,IC%20chips/LE-MM103_4_b.jpg
