9 Piece Bongo Drum Shell
8,538
22
Posted
Introduction: 9 Piece Bongo Drum Shell
This will show you how to make a bongo drum (shell only) without a solid piece of wood.
Step 1: The Math
We chose to use 9 pieces of wood to make the shell. The math behind this is that esentially we are trying to make a circle. There are 360 degrees in a circle. we are using 9 pieces. two of the sides of each piece are being cut. 2x9=18, and then we divide 360 by 18. This turns into 20, so each side of each piece of wood will be cut at a 20 degree angle.
Step 2: The Pieces
After the cutting, this is what we ended up with. 9 pieces with two sides with a 20 degree angle.
Step 3: Glueing Pt. 1
The rest of the drum is very simple. Glue and let dry for approximately 30 min. We paired 2 pieces together and glued them together. One rested on the table, and the other was held up by a few extra pieces of wood. We then used a foam brush to even out the glue.
Step 4: Glueing Pt. 2
We then paired those pairs up and also added the 9th piece to one of them.
Step 5: Glueing Pt. 3
This is the final glueing stage. We put both of the halves together, but this time the wood is upright. We used a strap clamp to keep the wood pieces together. If you do not have a a strap clamp, you could use a bungee cord.
Step 6: Sanding
The final step is the easiest. Sanding.  Once the glue is dry, all you need to do is sand down the sides and the corners to make the drum look nice and so there won't be any splinters. We used a sanding machine to make it quicker.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
3 Comments
I've seen this construction method before. Just google "stave drums" it's cool stuff.
Nice drum shell - don't forget to post the rest of the project when you skin the top? On that note, how are you planning to stretch the drum head and secure in place?
Very interesting and well done.
About step 1, the math is perfect when the body is prismatic, but not when it is piramidal. In this moment I don't remember well, but I had that problem designing my plain mirrors based solar cooker.
I mention here that because maybe somebody want apply the same method for make a conic body.
