9 Square in the Air
86,858
64
27
Published
Introduction: 9 Square in the Air
About: I am a middle school math teacher in North Central Indiana. I have taught for the past 11 years. In addition to teaching middle school, I have taught at the university level for the last 7 years, write dig...
A couple of teachers wanted to bring the typical youth group activity to life in the middle school. So we set out to redesign the game so we can have more kids playing at a fraction of the cost.
Step 1: Typical 9 Square in the Air
The game is a 9 square that sits anywhere from 6 to 8 feet in the air depending on size and age of those who are playing.
The pieces needed are nothing more than connector joints and pipes.
Online the connector joints cost $339 and the the complete kit runs $799. A large investment for any church or school for a game that only allows 9 students to play at a time.
Step 2: Problems With PVC Pipes
The first design problem we encountered is there is no PVC joint that has 5 connectors. This meant we would have to find a way to connect our pipes differently if we were going to design our own.
Our solution was to take the vertical support and move to the midpoint on each square. This idea would solve two problems. The first of which is now we did not need 5 piece connector. We will discuss the other issued solved in a later steps.
Step 3: Size Vs Height
Knowing the squares themselves would be cut to put support pieces in to address the connector joint in the previous step, we looked at the access we had to PVC pipe.
We decided to go with 2 in pvc pipes that came in lengths of 10 ft.
Question is how big of square did we want, and what height?
We decide on 5 ft by 5 ft squares and that would be 7.5 ft high. These measurements saved us many cuts, and saved us on wasted PVC pipe, remember we are teachers and we are on a budget. We cut the 10 ft pipes into 7.5 and 2.5 pieces.
7.5 ft pieces serve as the support
2.5 ft pieces are the squares(with the connector joints we pick up a few more inches so the square is a little bit bigger that 5ft by 5 ft.
So we have a 25 sq ft box at a height of 7.5 ft. Good size for our aged range of 12-14 years old.
ADVANTAGEOUS TO OUR DESIGN
One size of pipe to order, one size of cut to make, and the build only works with 2 different lengths, either its a vertical 7.5 ft piece support, or its 2.5 ft. square piece. No confusion on the build.
We had to count up our pieces and arrived at:
24 7.5 ft pieces
48 2.5 ft pieces
A total of 30 , 10 foot pvc pipes will be needed for on 9 square in the Air game.
PVC 2" x 10 ft pipe cost $4.49 for a total cost on pipes $134.70 in PVC Pipe.
Now its time to take on the connector joints.
Step 4: The Build
Working from the inside out we began to piece our design together. We decided to add bushings onto the end of the vertical poles to provide extra grip as well as protection to the floor. We built the squares first and then with a few extra hands we were able to lift and support the square with 7.5 ft vertical poles. Its not a bad idea to glue a few of the connector joints but you will want to consider storage.
Step 5: Final Cost
30 PVC pipes 2in x 10ft at $4.49 per piece Total cost of pvc pipe $134.70
32 2in T connector joints at $2.48 per piece Total cost of T joints $79.36
4 2in 90 degrees elbows at $.95 per piece Total cost of elbow joints $3.80
24 2in Bushing at $0.84 per piece Total cost of bushing $20.16
FINAL COST : $238.02
Online cost : $799.00
Savings : $560.98
ADVANTAGES TO OUR DESIGN
70% Cheaper
Step 6: How to Play
9-Square in the Air Rules
KING VERSION
1. The “king” serves the ball from the center square to any other square by hitting the ball up and out of the top of the center game square.
2. Players must return the ball to another player’s square.
3. If a player fails to return the ball to another player’s square, that player is out.
4. A double hit results in elimination.
5. During game play, players are not allowed to touch the game structure. Touching the game structure results in elimination.
6. When a player is out, they leave their square and move to the end of the line. The other players advance to fill the square of the player who just got out.
TEAM VERSION
Players will compete 4 on 5 where team mates are staggered in a checkered pattern. Play similar to rally scoring in volleyball, players try and prevent the ball from landing in their square. The ball can be set into play by the team that scored last, or alternate turns. Game ends when one team reaches a set point limit. More players is not necessarily an advantage as it means you have more squares to cover. This style leads to setting teammates up to score points by incorporating passing between players.
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
  • Casting Contest
    Casting Contest
2 Questions
Where did you purchase your PVC pipe? The 2" pipe at home depot is over $6 for 10ft. I'd like to find the cheaper pipe you used. Thanks!
Help confused here. I see the amazon expensive one I can buy for the $700+ dollars and I see where you say I can get it cheaper but can't figure out how to buy it? email me at Ronette.costain@k12.sd.us with any guidance you can give as I am wanting to get it ASAP for a glow night I am planning in May
27 Comments
That's awesome you saved so much money!
draw it out with a crayon for me... I save money if I go to my local store and build it myself? Or is there way to buy it online cheaper that I am missing?
Does anyone know where I can find instructions to build a permanent structure for outside use? Can be wood, metal, pvc...
With the 9square website having two patents can I make your design legally? I love the design by the way (I'm a college student on a budget), I just want to make sure I can do it.
You are not selling it, I'm sure its fine for personal use.
Anyone know of a permanent version of this structure? All metal for a playground that could also be hung on? How tall would you say it should be if it is for K-6?
outside generally doesn't work well as the standard ball well get blown away easily
These are being played outdoors regularly, the standard balls works just fine, unless you are talking about playing on a super windy day.
What size and kind of ball do you recommend? I've looked at Walmart and the balls they carry either seem too large or too small. I've also looked on Amazon but not sure of size. Thanks!
9 Square in the Air company sells replacement balls, they don't have it listed on their site but you can email and buy from them. The price is reasonable compare to their set.
Asking for a middle school - does it scratch the a wood gym floor? Thank you
have any of you made this game for elementary kids? what height would you recomend?
I bought upright drawstring christmas tree storage bags. They are sturdy and have handles. Largest i could find was 60" so the pvc sticks out the top but works great. I also bought a mesh sports bag to keep the connectors and ball in. Then i had an old metal upright shopping cart laying around that they fit perfectly in so i can roll them in and out.
we found 5 way fittings on Amazon and with standard fittings came in at around $220
There's a great site out there that carts non standard furniture grade pvc grade fittings that I think would fit your needs perfectly.
http://www.formufit.com
Check it out and let me know what you think.
As for your instructible, this is a neat soon on the game I used to play as a kid.
Hope the site helps.
This company sells their fittings on Amazon, and they're Prime eligible! 2 day shipping!
Great idea! I am definitely going to do this. One question. Do you think 2" PVC is really necessary? I just wonder if you could get away with 1" pipes to save some money...or do you think the structure would be too wobbly with 1" pipes?
I just built one with 1" pipes. It's very wobbly, but can be stabilized by staking wires from the corners down into the ground, like one would do with a big circus tent, LOL. We also used the cheap PVC, a step down from Schedule 40. Don't skimp trying to save money--get the Sched. 40. It's sturdier.
Great question.
We are middle school and we expected a lot of mileage on them. I would bet smaller would also work and it will definitely store better.
