From heart attacks to zits, in the garden and the laundry room, aspirin has a ton of uses beyond relieving pain. Some of these I've tried, others I should try but haven't, and a few I hope to never try. You, the reader, are left to judge which is which.
Remove these ads by
Signing UpStep 1Heart attack mitigation
The aspirin has an anti-clotting effect that inhibits platelets from doing their little plateletty jobs. You know, hanging out together in large groups, getting rowdy, and creating thromboses. This is perfect for those occasions when you're on the verge of death due to an unplanned cardiac episode.
According to the American Journal of Cardiology, chewing the aspirin has a more immediate effect than washing the pills down with a cool glass of water. So that's good to know. Especially if you're a man over 50 with less plaque on your teeth than in your arteries.
I learned a bit and had some good laughs while reading your 'ibles.
Thanks!
just thought id share...:)
1) gastritis : irritation with possible bleeding in the stomach
2) make a disease-based or drug-induced 'anti-coagulant' state into a serious problem.
3) make worse a cerebral bleed type of stroke
4) cause gout (as it competes with uric acid for the kidney's method of ridding your body of uric acid (urate). So, the urate increases and in some individuals gout can onset.
I'm not aware of anything ingested that can't have any negative side-effects ... yes, including food and water!
The best cure for hangover is not going overboard with your drinking, if you must get trashed, drink quality liquor instead of the cheap $10 bottle of vodka... The reason you have hangovers is due to the way the liquor was distilled, lower quality liquor is usually only distilled once, so there's still methanol left in the final product after the distillation process, which is what causes hangovers... Higher quality liquors are distilled multiple times (usually 4-5 times, but some have been known to be distilled up to a dozen times) to further reduce the amount of methanol left after the distillation process, and therefore the higher quality liquor is less prone to cause hangovers...
If you must drink cheap booze, drinking lots of water throughout the night and eating a couple slices of bread before you go to bed helps avoid or reduce the intensity of your hangover in the morning as well
As a lifelong migraine sufferer (albeit, slightly different than a hangover...) I've use weed as a pain reliever, and as a preventative. It's been found to have so many medical benefits - right down to relief of irritable bowel syndrome...so whose really to say that it might not work for hangovers? Until unbiased medical studies are done, no one can attest to that.
That being said, If you have the 'spins' at all, weed will just make you spin more and eventually throw up.
At least this is what I've found to be true.
Smoke weed everyday.
-friendly dermatologist.
It is a great double whammy of anti-inflammatory and keratolytic action.
But even 0,1% of female engineers in the world amount to more than 50 !!!…
Otherwise we would have so little of the whole type that we won't have to bother with Tchernobyls, BPs, CO2, and our regular leisures would still be reading, and chopping wood for the winter instead of fixing our Macs or surfing on the web !…
OK I'm joking. Many engineers (male or female) are very efficient people and work to ease our life, not poison it.
Still as I know at least 20 women engineer in my own city I'm sure that even in the USA, which is not the most prone towards equality between genders, you'll find more than 50 engineer women who do not need to be as sexy and beautiful as the latest Hollywood star to get a job in their field and be goddam as efficient as men !!!…
This was my "equality between sexes" deed of the day :-)
Have a nice week end !…
Greetings !
