From heart attacks to zits, in the garden and the laundry room, aspirin has a ton of uses beyond relieving pain. Some of these I've tried, others I should try but haven't, and a few I hope to never try. You, the reader, are left to judge which is which.
Step 1: Heart attack mitigation
The aspirin has an anti-clotting effect that inhibits platelets from doing their little plateletty jobs. You know, hanging out together in large groups, getting rowdy, and creating thromboses. This is perfect for those occasions when you're on the verge of death due to an unplanned cardiac episode.
According to the American Journal of Cardiology, chewing the aspirin has a more immediate effect than washing the pills down with a cool glass of water. So that's good to know. Especially if you're a man over 50 with less plaque on your teeth than in your arteries.
Step 2: Remove sweat stains
Crush up enough pills and mix with water to create enough paste to cover the sweat stain of your choice. Let it sit for several minutes then rinse. Launder as usual. This treatment is good for any protein-based stain, so pull it out for those times when you get some of that nosebleed on your shirt or dribble egg yolk onto your pants due to over-over-easiness.
Note: pound for pound, this is an expensive method of removing sweat stains (compared to using lemon juice, enzymatic meat tenderizer, or white vinegar), but it's a good thing to bear in mind if you're surprised by a serious stain in a random hotel room that stocks aspirin, but not meat tenderizer, in the lobby gift shop.
Step 3: Restore hair color
Dissolve 6-8 aspirin pills in water, then rub the solution into your hair. Let it sit for 10 minutes and rinse it out. The greenish effect should start to disappear after a couple of aspirin washes.
When I was in fifth grade, there was a girl in my class with hair so blonde and fine it looked like fiberoptic wire. She was a swimming fiend, so her hair was always just a touch too green in the summertime. In middle school, she acheived the Edenic self-consciousness of Eve and began to use aspirin to fix the greenness. She is now incredibly successful and one of 17* female engineers in the whole world. Aspirin helped her become a foxy materials engineer, imagine what it could do for you.
*I know that there are more. But there are still too many girls being discouraged from careers in science and math. The real number is probably in the low to mid 50s.
Step 4: Zap zits and punish pimples
Crush up the pill and add some water to make a paste. Apply the aspirin paste to your pimple and wait for several minutes. Rinse off without rubbing too much, and the pimple should diminish in redness and size. Spot treatment for those "haven't showered since Friday" weekend camping trips where you want to look your best.
Possibly true fact: the taste of salicylic acid can discourage bears from gnawing on your face.
Step 5: Treat bug bites and stings
A great little camping piece of know-how: willow trees and their ilk contain the natural equivalent of Bayer. Some bark will have a similar effect to the paste described earlier. When I was a Boy Scout in Colorado, we used to strip small sections of bark off of aspen trees and treat the bug bites we brought upon ourselves by being fragrantly scrumptious.
Step 6: Organic gardener's dream
According to the exhaustive research I just performed on Wikipedia, salicylic acid can induce specific changes in root, stem, and leaf structure that create more robust plants. It can also help fruits and vegetables grow bigger and stronger. It will help your plants resist disease, insects, and unusually weak hailstorms.
Additionally, an aspirin solution will also help your cut flowers last longer in the vase so you can go nearly a full week before raking up the dead petals. Unless you're playing the "he loves me, he loves me not" game, in which case you should just count the petals in advance to determine your romantic status and let the aspirin keep the bouquet pretty.
Step 7: Treat dandruff
Crush up two aspirins into the normal amount of shampoo you use, then leave it in for several minutes. Don't do it with a dandruff-specific shampoo, but this is a great method of maintaining great-smelling hair without distributing enough fine white powder to cause an asbestos scare or DEA raid. If you're concerned about wasting water while you wait, shut off the water and just hang out for a minute while the aspirin does its job.
Step 8: Squeeze the last juice from a car battery
Pry off the cover of the battery with a screwdriver or pry bar and drop two crushed aspirin into each cell of the battery. Theoretically, this should cause a chemical reaction that changes some of the sulfuric acid into acetic acid and provide just enough oomph to get the engine to start turning over.
For bonus MacGyver points, try using cola to take any corrosion off of the terminals. If it's really cold outside, heat up the battery with whatever you've got on hand. Pouring hot water over the engine and battery itself (with everything disconnected) might help. YMMV. Literally.
Step 9: Treat a hangover
After a long night out on the town, if you are in any condition to do so, take two aspirin before bed. These will help decrease the severity of the hangover in the morning by inhibiting prostaglandins. (You know you don't want those prostaglandins running around inside of your body like evil elves while you have the spins.) Then take two more in the morning with some breakfast. It'll decrease the severity of the morning headache and decrease the elf- or prostaglandin-related swelling.
If it's one of those mornings where the hair of the dog sounds as appetizing as actual canine fur, aspirin's your ticket to a productive day.
Visit Our Store »
Go Pro Today »
For those that use this method: It's a great treatment, but DON'T use it too often if you want to keep using it. Your skin can build up a tolerance to the aspirin, and make the treatment cease to be effective. This is good to help calm skin in emergencies, but not on a regular basis.
ALSO, Salicylic Acid (asprin) makes your skin more susceptible to sunburns. if you are going to use this treatment, use sunscreen as well.
For face masks like dollgrownup suggested, you can dissolve one or two (depending on the size) uncoated aspirin in some aloe or honey . Aloe moisturizes and soothes skin, where honey has natural antibacterial properties. Combined with the aspirin, which has anti-inflammatory properties (duh), and exfoliating properties, it makes a great mask to help sooth skin and fight acne. Just remember to use sunscreen when being out in the sun after using this treatment.
I have also read rumors about "aspirin burns" due to aspirin used on the skin. It is always a good idea to test whatever you are using on a small area of skin to make sure you do not react.
Aspirin is used in a lot of store bought face washes and whatnot, but there are certain risks involved in making your own mask that you might want to look up if you are in the least bit concerned.
I learned a bit and had some good laughs while reading your 'ibles.
Thanks!
just thought id share...:)
1) gastritis : irritation with possible bleeding in the stomach
2) make a disease-based or drug-induced 'anti-coagulant' state into a serious problem.
3) make worse a cerebral bleed type of stroke
4) cause gout (as it competes with uric acid for the kidney's method of ridding your body of uric acid (urate). So, the urate increases and in some individuals gout can onset.
I'm not aware of anything ingested that can't have any negative side-effects ... yes, including food and water!
The best cure for hangover is not going overboard with your drinking, if you must get trashed, drink quality liquor instead of the cheap $10 bottle of vodka... The reason you have hangovers is due to the way the liquor was distilled, lower quality liquor is usually only distilled once, so there's still methanol left in the final product after the distillation process, which is what causes hangovers... Higher quality liquors are distilled multiple times (usually 4-5 times, but some have been known to be distilled up to a dozen times) to further reduce the amount of methanol left after the distillation process, and therefore the higher quality liquor is less prone to cause hangovers...
If you must drink cheap booze, drinking lots of water throughout the night and eating a couple slices of bread before you go to bed helps avoid or reduce the intensity of your hangover in the morning as well
As a lifelong migraine sufferer (albeit, slightly different than a hangover...) I've use weed as a pain reliever, and as a preventative. It's been found to have so many medical benefits - right down to relief of irritable bowel syndrome...so whose really to say that it might not work for hangovers? Until unbiased medical studies are done, no one can attest to that.
That being said, If you have the 'spins' at all, weed will just make you spin more and eventually throw up.
At least this is what I've found to be true.
Smoke weed everyday.
-friendly dermatologist.
It is a great double whammy of anti-inflammatory and keratolytic action.
But even 0,1% of female engineers in the world amount to more than 50 !!!…
Otherwise we would have so little of the whole type that we won't have to bother with Tchernobyls, BPs, CO2, and our regular leisures would still be reading, and chopping wood for the winter instead of fixing our Macs or surfing on the web !…
OK I'm joking. Many engineers (male or female) are very efficient people and work to ease our life, not poison it.
Still as I know at least 20 women engineer in my own city I'm sure that even in the USA, which is not the most prone towards equality between genders, you'll find more than 50 engineer women who do not need to be as sexy and beautiful as the latest Hollywood star to get a job in their field and be goddam as efficient as men !!!…
This was my "equality between sexes" deed of the day :-)
Have a nice week end !…
