Step 8: Squeeze the last juice from a car battery
Pry off the cover of the battery with a screwdriver or pry bar and drop two crushed aspirin into each cell of the battery. Theoretically, this should cause a chemical reaction that changes some of the sulfuric acid into acetic acid and provide just enough oomph to get the engine to start turning over.
For bonus MacGyver points, try using cola to take any corrosion off of the terminals. If it's really cold outside, heat up the battery with whatever you've got on hand. Pouring hot water over the engine and battery itself (with everything disconnected) might help. YMMV. Literally.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
negative points, though, if you forget that it's a battery you're peeing on and shock yourself.
and it was mainly a joke, but I feel like it's a point that could potentially be defended.
actually, it'll probably just remain unknown - nobody's going to do that.
Besides... wouldn't it be more likely that someone would pee in a container first, then pour it on? One would have to have a 60" inseam, or climb up over the engine...
This is such a dumb subthread....
LOL
I suppose if you're in the middle of the desert you may have to resort to such measures...
washing off your terminals with hotwater to clear corrsion is something which should be done regularly - cokes just gonna do it quicker (and you really DRINK that muck????!!)
