The headlamp will produce white light, however, it is also possible to replace the white LED's with other colors if you so desire. The LED's will be wired in parallel, so that each LED produces the maximum amount of light possible.
Tips:
*Tape up your exposed connections in this project with electrical tape.
*Use a dry-erase marker to mark positions, because it rubs off if you need to adjust the position.
*Handle soldering irons and hot glue guns with caution - They are hot!
*Build the circuit on a breadboard to make sure it works and that your components work too.
Remove these ads by
Signing UpStep 1Components and Pieces
You will need:
2 - high intensity white LED's (3.2 volts is common)
1 - customizable printed circuit board
2 - 470 ohm resistors (yellow, purple, brown in resistor color code)
1 - slide or toggle switch
1 - 9 volt battery plug
1 - 9 volt battery
1 - small project box (can be a mint tin, I use a $0.59 battery box from Fry's electronics).
1 - headband
3 - (separate pieces) 6+ inches of electrical wire (can be any gauge) or a spool of wire if you have one.
To build the light, you will use:
A soldering Iron
Electrical Tape
Solder
Hot Glue
*I recommend buying your tools and components at Fry's or Radio Shack. Use a combination of components from both stores to take full advantage of pricing differences.
Wobbler, I want to ask
it seems you are proficient in LED lights, may I ask your advice?
I have made a series of LED lights on my bicycle spokes, for driving at night I use a 9 volt battery with 9 pieces of white LED 3.3 volts, which I connect each with a 330 ohm resistor 9 pieces 1/4 watt. its durability is approximately 30 hours later the lights dimmed, is there any way to be more durable?
You could also use other than white LEDs to get the LED voltage down, maybe green or amber?
As a final thought, don't use 9 LEDs. See if it looks just as good with 3 or 6. That also will increase your light life.
As an aside, I've often thought of doing this with either a slip ring contact to allow the batteries to be off the wheel or some sort coil passing a bank of super magnets, the reverso of some of the rear light ones you can buy but not got round to it yet (ever?) See Nagutrons http://www.instructables.com/id/Magnetic-Induction-Bike-Lights/ for the basic idea.
http://en.wikipedia.org/wiki/Light-emitting_diode
http://en.wikipedia.org/wiki/Nine-volt_battery
If I use 2AA alkaline battery, the durability will be quite long, it's cheaper and I do not need to use another resistor is not it?
There is a good online resistor calculator for single, parallel and serial LEDs here:
http://ledz.com/?p=zz.led.resistor.calculator
You just need to know the battery voltage you'll be using, the LED voltage and current (which you can usually find from the sellers). LEDs are also usually more efficient at lower currents, so using two LEDs with the same combined total current can provide more light than one LED at the equivalent total current.
