9 Volt USB Charger
2,062
35
7
Posted
Introduction: 9 Volt USB Charger
This is a portable usb charger made for a car charger and an Altoids tin .
Step 1: Parts
You will need an Altoids tin, USB car charger, 9 volt battery and clip ,and a small toggle switch
Step 2: Soldering
Solder the negative wire of the battery clip to the negative terminal of the car charger. Solder the positive wire to one side of the toggle switch then solder a wire to the other switch terminal and the other end of the wire to the positive terminal of the car charger
Step 3: Drilling
Drill a hole for the switch and the usb
Step 4: Assembling
Put the parts in the Altoids tin
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
7 Comments
I tried it but it doesn't work
instead of using the car adapter you can unsolder the USB with a little but of work and use an L7805 (5V regulator) and make it so you can use any power source between 7-24 volts to get the perfect 5v a phone needs. great work tho very simple
you can see my instructables here: https://www.instructables.com/id/PowerBank-2Usb-2200mAh-26watt/
electronics circuit dont permit you to use all power inside battery(the usb adapter
work between 12/24 volt) under 12volt.Use two battery(serial connect) to have 18volt and a best result and all power available inside battery...... :)
