3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
9 Volt battery adapter for Arduino
This is super simple but very useful if you are in a hurry or just like to do things yourself and on the off chance you didn't know, this is about the easiest way to add mobile power to your Arduino.
After looking at a number of battery power solutions for Arduino ranging from Lithium Backpacks to Minty Boost kits I decided I didn't want something even that complicated. Granted, the 9 Volt isn't the most efficient battery for the job and it's expensive compared to others, but it is widely available and compact.
It is also possible to wire a battery adapter directly to the pins but I wanted to use the DC power jack and not have any wires running to the pins than I have to.
I did this for my Mega but it should work with any of the Arduino boards with a 2.1mm jack. You can use either the 2.1 X 5 or the 2.1 X 5.5, both will fit. 9V DC is right in the middle of the ideal range for the on board power management circuitl. So, no resistors, caps or other components are needed. (They are rated up to 12V but I don't think I'm brave enough to test it with a Mega since you can't just replace the chip if you cook it.)
You can buy these assembled from Adafruit  but I needed a couple of them and didn't want to wait for the mail or pay shipping. You only save a few dollars but you get to do it yourself and you have the option of extending the leads if you need to.
Step 1Materials
Materials
1 9V battery snap connector
1 Coaxial plug 5X2.1(K) size is probably best but the 5.5X2.1(M) will also work
A couple inches of 1/8 inch shrink tube and an inch or two of 1/16 inch
Optional
A few inches of 27 X 1 3/8 inner tube. The 1 3/8 is the important part
An inch or two of Velcro
Tools
Soldering iron and solder
Wire cutters
Hobby knife or scissors
14 comments
Jan 2, 2012. 1:11 PMRegulators.Mountup says:
I am extremely new to this field, and I am really whipping myself up into a frenzy about it - buying all kinds of motors and tiny components, etc. I'm pumped. Anyway, I really wanted to free myself from the USB/wall cord, so I went ahead and made this simple 9v battery pack based off this instructable. I might also add that this was my first time soldering. It really turned out pretty well, although I couldn't get the heat-shrinking tubing to . . . shrink. Pointed a hair dryer at it for a hot minute to no effect.
Jan 10, 2012. 2:20 PMTedRobotBuilder says:
If the hairdryer is on high and you hold it very close it should work. If the air hot enough to burn your fingers it should be hot enough. I use a space heater! XD
Aug 30, 2011. 6:20 PMbears0 says:
just FIY, if you have an Energizer battery you can open it up and use the little top piece for a connector. Energizer batteries have little AAAA batteries inside so you dont have to worry about acid. just solder the wire to the little disks and pop it on a fresh battery. i have done this a couple times. (it might be possible to use any other type of battery as long as you are careful and you don't break open the inner "ACID CONTAINMENT UNIT".) lol BE SAFE.
Jun 1, 2011. 5:48 PMThe nerdling says:
i made on ad it works like a charm it ahs a swithc and everything
Feb 3, 2011. 5:08 PMbrawns214 says:
9V is certainly quite usable for arduino boards. I think they suggest not using anything more than 12V.
I have to ask a question though, why wouldn't you just insert wires into Vin and Gnd? You still need the 9V snap thing though.
Feb 9, 2011. 8:25 PMIdloid says:
Thank you for this i was needing it I'm new usinr arduinos :)
Feb 1, 2011. 9:20 AMmatrix0111 says:
grateful
I can myself making ?
Jan 27, 2011. 8:54 AMrtty21 says:
nice!
Jan 26, 2011. 2:09 PMSzajba says:
its gonna win! for sure :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
127
Author:Culturespy(Barnhart Photography)
