3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
900,000 volt Van de Graaff Generator Using Cheap Parts
Step 11Base (comb and bottom roller)
The bottom comb position in relation to the bottom roller is shown below.
Note that the roller will be turning counter clock wise and that the pins are just above were the belt will leave the roller.
4 comments
Apr 7, 2012. 8:29 AMmethoxypropyl says:
Your instructions are nicely done. The adjustment of the brushes could be made if you use a spacer like paper of various thickness to make positioning easier and more parallel. I haven't started yet but I assume the belt will have a tendency to centrifugally move towards the brushes if they are above the tangent point off the rollers? You say to move them just above where the belt is starting to loose contact with the roller. Are you saying that is very important or can the brushes be at the tangent of belt and roll? If so, then the likelihood of scraping is reduced.
Feb 2, 2010. 8:04 PMseansippo says:
do i want the bottom comb touching, or like the top one where it is close as possible without touching the belt?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:nickademuss
A+ certified with a degree in electronics engineering, and professional photographer using Nikon digital and film cameras for many years.
