Step 16Top roller another view and belt construction.
After you have cut and glued the belt, you can put it on, you simply use the four support bolts to tighten it up, don't go to far you just want it tight enough to spin, and not slap the side of the column when its up to speed, this will kill your charge. If your belt does not track right you can fix that by moving one side of the supports up a little at a time, go slow and make the belt center in the rollers. You can also "crown" one of your rollers, that is to make it "keg" shaped. The downside to this is that you lose a little surface contact and in turn a little recharge power.
Optional: you can make the top roller adjustable as well to help center the belt.
I am going to try a intertube for my little 250 kv and see how good or bad it works. Unless someone already tried. zap zap
