3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
900,000 volt Van de Graaff Generator Using Cheap Parts
Step 20In action
In action
3 min, exposure in a dark room, the other ball is grounded and attached to a stick.
See it and other photos that I have taken here:
http://www.flickr.com/photos/22560053@N04/
Nickademusss Photo Stream
Most of the best visuals with a Van De Graaff are in a dark room, the light is subtle.
Enjoy email with questions :)
5 comments
May 26, 2011. 6:41 PMCrazy-Inventor says:
I have a doubt, if this Van De Graff generator can produce 900,000 volts, then why can't we use it for electric supply for a house? or other purposes?
Jul 10, 2011. 3:19 AMmakincoolstuff says:
and i forgot to say, a house needs like 50 amps so 0.2209 amps would power a 25 watt light bulb, it probably couldnt even power your laptop. And also van der graafs need to charge up to 900000v, its not constant. so powering a house would simply be impractical.
Jul 10, 2011. 3:08 AMmakincoolstuff says:
the amperage is also far too low: 900,000 volts at 27 micro amps will produce 110v at 220.9 milli amps (0.2209 amps) when a house requires far more amps then that. and not to mention the losses when converting 900000v to 110v
Jun 9, 2011. 9:59 PMtinstructable says:
This generates static electricity, and voltage like this isn't that useful. It will jump through insulation on wires, and the amperage of this is also extremely weak.
Jun 26, 2009. 4:50 PMscliffor says:
I'm having a really hard time bending the 3/4 " copper tubing, any advice on that?
Jun 27, 2009. 11:02 AMscliffor says:
Thanks for the info. I did try that (after reading your instructional) but you must be much stronger than me as I hardly made a dent in the copper. I've been using 2 ft pieces, I'm on my third. The last I heated and cooled several times to anneal it, then filled it with sand and still had trouble bending it. And it crimped. I'm trying to construct a wooden tubing bender like I've seen for smaller diameter pipes that I can screw to a wall or something solid and really torque a pipe on. I'm really intrigued about the ice in the pipe. I just can't imagine how you bent it! Thanks for your help and a great instructional!
Dec 19, 2009. 8:44 AMredjohn says:
What can I use to make the rollers stay on the VDG????
Dec 19, 2009. 8:46 AMredjohn says:
By the way Thank you so much for the awesome guide and tips!!!! :[)!
Dec 17, 2009. 10:24 AMiguanian says:
I'm building a VDG using different methods, but this got me thinking about the copper ring.
Since the sphere is such a pain, and the main issue is sharp edges, why not just use concentric rings of pipe to build a toroid/sphere?
A large enough diameter pipe would work for a toroid, but impractical to do that sort of bending at home. Since only the outer surface matters, several rings stacked up would accomplish the same effect.
Or am I missing something?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:nickademuss
A+ certified with a degree in electronics engineering, and professional photographer using Nikon digital and film cameras for many years.
