9V Battery Snap Connector From Scrap
3,459
13
Published
Introduction: 9V Battery Snap Connector From Scrap
About: UConTroll is a Wi-Fi enabled controller that lets, Makers and hobbyist control their devices using their iPad, tablet PC, smartphone or laptop. Visit our Web site for more information, or to place an order:...
Next time you have to replace a 9V battery, UpCycle it before you recycle it.  I'm always building battery operated devices and never have enough battery holders or connectors around.  But I've found a quick and simple way to make 9V Snap connectors from discarded batteries.
1 - Carefully remove the top from the 9V battery making sure not to damage it.
2 - Cut 2 pieces of wire to the length you want - one black and one red. I typically use 20 or 22 gauge wire.
3 - Turn the battery top over so the terminals are facing down.
4 - Solder the red wire to the female terminal (the larger, cup-like one), and the black wire to the male terminal.
5 - If you want to insulate the connections you can use a dab of hot glue, or cover them with tape.
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    3 Comments
    like it must try
    simple and genius !
    Do you have to cut off the terminal side of the battery because you didn't mention anything about that.
