3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
9V IR detector
9V IR detector
This is a great, simple project to make a small and robust 9V IR detector. It can be used to seek out security cameras that use infrared light to "see" or to check if your remote control is still working.
Step 1What you need
What you need
For this project you will need:
-A 9V battery clip with a flat cover made of plastic
-A 9V battery
-LED (any color although it should be clear in order to see it better)
-330 ohm resistor (orange-orange-brown-gold or silver)
-Infrared Phototransistor
-perf board (see 2nd picture)
-double sided mounting tape
-wire
-needlenose pliers
-wire snipper
-dremel or hack saw to cut perf board
-clear epoxy-like glue
-Soldering equipement:
      -soldering iron
      -solder with flux core
A shematic is given in step 12, picture #4.
69 comments
1-40 of 69next »
Nov 15, 2011. 7:39 AMm1s73r says:
Is it possible to increase the range of the IR Phototransistor? I've tried it with my TV remote but it does only work in range of approximately 4 inches... Also, I have an idea, couldn't you add a red LED, which light up if no Infrared Signal is in near?
Thanks
Oct 7, 2011. 4:23 PMaxeman911 says:
is an Infrared Phototransistor the same thing as a infrared LED?
Oct 9, 2011. 10:24 AMaxeman911 says:
so what would happen if i were to replace it with an infrared LED would that detect anything or would it like interrupt signals or anything?
Jun 5, 2011. 5:38 PMkill-a-watt says:
Don't you need a filter that passes (near)-IR only as a filter, or is the detector itself sufficient to avoid triggers from visible light?
May 2, 2011. 11:04 AMaesquivel says:
Will the battery drain if no IR is detected?
Jun 5, 2011. 5:35 PMkill-a-watt says:
I'd measure that to be sure. If it's only a few milliamperes then you won't notice any difference compared to the shelf life of the battery, so it would not matter. Otherwise, adding a switch or removing it from the battery should do the trick.
Jun 4, 2011. 9:25 AMarbita2 says:
good good good
May 29, 2011. 11:59 AMkel noseh says:
simpleness is greatness
May 10, 2011. 8:56 AMskrubol says:
You have the LED labeled as Infrared LED. That should be visible LED shouldn't it?
If you need higher sensitivity, there are also photodarlingtons, which, if you aren't familiar with darlington transistor configurations, have 10-100x the gain.
May 9, 2011. 3:17 PMfalcotheimpaler says:
Now, if this does what i'm assuming it does, the LED should pulse with the frequency of the IR code being sent to the transistor.
if so, one could replace the LED with another IR LED, (and potentially an extension lead) and create a low-cost IR repeater, for using remotes across corners, in other rooms, etc.
(I tend to find practical uses for things like this)
May 9, 2011. 2:47 PMXOIIO says:
Not a bad idea, I used to build these to test if remotes were working. As for detecting night vision cameras, they do horribly. Not enough LED's to pick them up well, and these IR LEDS are weak, they only work well within 10 feet, otherwise they barely do anything.
Apr 28, 2011. 4:13 AMrobot1398 says:
the same instructable
http://www.instructables.com/id/IR-Detector/
May 1, 2011. 6:40 AMpdub77 says:
I would argue that this is not the same. This build is quite a bit more elegant and therefore worthy of its own instructable.
May 8, 2011. 1:57 AMrobot1398 says:
u r correct
May 3, 2011. 8:18 PMAT says:
I just love simple! Great project.
I know why you used a 330 ohm resistor. Not everyone will. Could you add a simple calculation on why a 330 ohm resistor with the 9v battery? :-)
May 5, 2011. 9:30 AMAT says:
Just a simple Ohm's Law should do it. :-)
May 4, 2011. 4:58 PMGoodhart says:
The schematic has the output LED labeled Infrared LED which means one could not see if it were ON or not (and once it was on, it would keep the IR phototransistor ON and drain the battery.
May 1, 2011. 8:24 AMder_fisherman says:
Hi,
great idea and could be very useful when testing for IR from remotes and the like, but I personally always like to see a circuit diagram before building anything, even something this simple/easy......can you add a simple sketch of the connections.
I could probably work it out myself, but me being born lazy......
For anyone else who maybe wants to understand the operation better, they may agree with me.
Full marks though for simplicity and ease of use, many thanks.
Regards
Andy
PS If there is already one here and I did not see it, I am VERY unobservant, apologies/sorry!
May 3, 2011. 2:14 AMVenemot says:
Well actually there is.....the last pic on the last page is a schematic of the whole circuit...!!!!
May 4, 2011. 9:04 AMder_fisherman says:
Many thanks, I thought I may have overlooked it somehow.....
Regards
Andy
May 3, 2011. 5:46 AMkill-a-watt says:
I might suggest that at least add text to the intro saying there's a schematic on step 12. You may think it's so simple that the schematic is not needed, and that's true, but think of the diagram as a "Cliff's notes" of the project.
First thing I did was hit "show all steps" and then skim for the schematic (and then fav your project).
May 2, 2011. 1:30 PMtechrobo says:
cool!
May 2, 2011. 10:26 AMMadCobbler says:
I love minimal component projects, but a schematic or circuit diagram would help clarify what your are doing.
May 2, 2011. 8:18 AMazharjaved2000 says:
CIRCUIT DIAGRAM, EVEN IF IT IS SCRIBBLED BY HAND. THANK YOU
May 2, 2011. 1:46 AMSuyogaerospace says:
Circuit diagram please
May 1, 2011. 8:04 AMbkaspersky says:
can i use this http://www.cricklewoodelectronics.com/Cricklewood/product.php?productid=20865&cat=0&page=1
May 1, 2011. 10:54 PMstackerjack says:
No, this is a diode, which emits I.R, light.
You need an I.R, detector.
Try Maplins, or Radiospares.
May 1, 2011. 1:47 PMbkaspersky says:
help?
May 1, 2011. 4:07 PMleggomylegoeggo says:
it apears to be an IR LED, not an "ir phototransistor". I don't know, but it probably wouldn't.
Apr 27, 2011. 6:15 PMcompaqxp123 says:
I've wondered if you could send music over IR. For example have a transmitter hooked up to the radio, nothing complicated there, and have a recived on the other end connected to an amp.
Perhaps I'll try and Idea I have.
May 1, 2011. 10:10 PMMarche says:
You can! Google IrDA, it's been around for ages. If you want to take a more hacky approach, you could even transmit the raw PCM via IR serial. The serial over IR might take way too long to be practical though :P
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Candymanproductions
