Step 12You're done!/Problemfixes&circuit diagram
1. Check if your battery has enough juice (the "putting the contacts on the tongue" trick will work)
2. Make sure all the solderconnections are nice & smooth
3. Check if there any shorts in the circuit (solderbridges that shouldn't be there)
4. Check if any leads/wires from the parts or battery connector are broken, sometimes too much stress
on the parts makes them break.
5. Did you put the LED & Phototransistor in the right way around / did you get the polarity right?
As a help I added a circuit diagram as pic #4.
For all the others:
Fetch a 9V battery and try your IR detector. Clip it on and... you're done! Have fun!
Comment, rate & follow!
Thanks
You could add a red LED, but that would use up too much circuit board space to make it fit on a 9V battery clip.
If you need higher sensitivity, there are also photodarlingtons, which, if you aren't familiar with darlington transistor configurations, have 10-100x the gain.
great idea and could be very useful when testing for IR from remotes and the like, but I personally always like to see a circuit diagram before building anything, even something this simple/easy......can you add a simple sketch of the connections.
I could probably work it out myself, but me being born lazy......
For anyone else who maybe wants to understand the operation better, they may agree with me.
Full marks though for simplicity and ease of use, many thanks.
Regards
Andy
PS If there is already one here and I did not see it, I am VERY unobservant, apologies/sorry!
Regards
Andy
First thing I did was hit "show all steps" and then skim for the schematic (and then fav your project).
