9V Mini Drill
1,174
31
Published
Introduction: 9V Mini Drill
This 9V powered drill is perfect for wood, PCB boards, bakelite, cardboards and many more.
Very simple to make, a perfect utility tool for DIY hobbyists.
At the end of the video you can see testing results!
Step 1: Things You Need
Things you need:
- Hammer shank
- 9V Battery
- 9V Battery Connector
- Mini Switch
- Mini Motor
- Velcro Tape
- Srew Terminal
Step 2: Saw Hammer Shank and Attach Switch
Saw hammer shank (something about 4 inches).
Then make a gap for the switch and attach switch with hot glue.
Step 3: Attach Motor
Now attach the motor, also with hot glue.
Make sure you use enough hot glue!
Step 4: Connect Wires
Attach the red cable from battery connetor to the switch.
Connect the black cable from battery connector to the motor.
Then use a little piece to connect the switch to the motor.
Step 5: Attach Battery
Now attach battery with velcro tape.
I used some electrical tape to make it stronger.
Step 6: Connect the Drill
Take a screw terminal and remove the plastic from it.
Now use it to attach the drill to the motor.
9V Mini Drill is ready now!!
Step 7: Test
Finally, take it to the test!
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    Where did you obtain a screw terminal?
