9V Solar Battery Charger by JoshuaZimmerman
Did you know that you can buy 9V rechargeable batteries?  You can, but they're rare in stores.  I recently bought some off ebay to use on projects and loved them.  Only downside is that I don't have a 9V battery charger and all the ones I found on ebay are quite expensive.
Luckily I'm resourceful and decided to build my own.  The entire project only cost me $10 and didn't take that long.
Cost: $10
Time: 1/2 Hour
Difficulty: Easy
Schmidty16 says: May 7, 2013. 7:58 PM
Dang i wish u were my 8th grade science teacher
bdailey2 says: Sep 3, 2012. 7:36 AM
How do you avoid over charging the battery?
JoshuaZimmerman (author) says: Sep 4, 2012. 8:32 AM
The method we're using is only a "trickle" charge, which means we don't have to worry about over charging. We're not throwing enough current at it to do any damage. They'll just stay topped off.
JeenJogi says: May 16, 2012. 2:33 PM
Commercial Solar Panels are Expensive!
Fact: It will take you more than 10 years to pay back
Solution: Using Surplus Solar Cells You can get pay back in 1-2 years
There is an Engineer from Chicago his name is John Sommer
He explain it All in his diy solar panels Blog Search for him using Google
Type "top diy solar panels" Open the first Result.
Note: Ignore the adds at the top.
rosebudfarm says: Apr 24, 2012. 3:10 PM
Awesome design! Those solar lamps are dump fodder for sure and easy to come by.
I am looking for a way to trickle charge 9v irrigation timers. Would this set-up be adequate and could I just piggyback the leads from the timer battery to the charger?
NickFiya says: Apr 12, 2012. 1:05 PM
Does this work with only 3 of the solar cells?
JoshuaZimmerman (author) says: Apr 12, 2012. 3:46 PM
Well 3.5V x 3 = 11.5, which is not going to be enough to charge up your 9V. You'd need at LEAST 12V, but more like 16 to play it safe.
Joshua
NickFiya says: Apr 13, 2012. 6:44 PM
Thanks bud
jim_2000 says: Sep 29, 2011. 7:19 AM
How much current do you get out of these cells?
JoshuaZimmerman (author) says: Oct 7, 2011. 1:21 PM
Something like 20mA. Usually less.
Thats what we need though. These 9V batteries are rated at only 280mA, and we don't want to throw more than 10% of their capacity at them at once or they'll die.
JoshuaZimmerman (author) says: Sep 22, 2011. 9:03 AM
If you're having issues finding solar cells, you may just wish to buy three 6V cells. I do have some small ones on my website that work wonders.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
