9V Beautiful Small Lamp
3,316
15
13
Published
Introduction: 9V Beautiful Small Lamp
About: My name is marjancho and I love electronics,makeing gadgets,hack and pranks.
this is smalest beautiful lamp that I have buildet,and It takes simple parts to build it
Step 1: Part List
Part list is:
1.Dead 9 volts batery
2.led diode
3.resistor 100 ohms
4.glue
Step 2: Conect the Parts
1.First you need to empty the dead batery,and make holes.then painted in any color,put in the led inside and fill with glue.
2.conect the resistor with the led diode,and conect to the top part of the batery just like on the picture
Step 3: Fill With Glue
Fill with glue the bateru box,and dont forget to put the led diode to bottom of the batery box
Step 4: Finish
This is yours smallest 9 volts lamp,ENJOY
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    13 Comments
    i agree that it is very nice, but it could be smaller also, it might be a good idea to use fiber optics or flexible light pipes if u want to equally distribute light to the upper holes
    people learning and talking on the internetz!?! O MY! theres a difference between an argument and a discussion. I was concerned about the about of current you were putting through the led, but it appears it should be fine. at least we know how to use the "reply" button. ;)
    your using a 100ohm resister with a 9V battery.....WOW. you are going to burn that led out pretty quickly. you should be using something closer to a 1K ohm resister, 10X what your using right now.
    Actually, 100 ohms is about right for a white LED, which is what the project appears to be using. Even a lower power LED rated for something like 2.5V @ 20 mA would only need 300 ohms. How did you come up with the 1K ohm figure?
    A 9V battery can deliver a lot more than 15 mA. A fresh one can supply a few amperes for a short amount time; more than enough to burn up an LED. The chart in your link shows the typical drain batteries might experience in use, not their rated output.
    The way to calculate the series resistor value for an LED, as in this project, is:
    (supply voltage - LED operating voltage) / required LED current = R in Ohms
    White LEDs usually operate around 3-4V. Assuming it draws 40 mA, you'd need a resistance of 125-150 Ohms. In this case, a little less is okay because 9V alkalines are fairly "puny" and the voltage will drop off rapidly.
    ultra bright leds are, by datasheep, maxed at 25ma, but ive seen them at ~30ma. ~40ma+ isnt going to destroy the led, but its going to have a much decreased life span. if he uses a bigger resister, his led would be just as bright and last much much longer.
    The 40 mA number was just an example and LED specs do vary. 100 ohms is in the ballpark. You have to remember the battery's internal resistance and state of depletion will have an effect on terminal voltage under load too. Going by Duracell's product data...
    http://www.duracell.com/oem/Pdf/new/MN1604_US_CT.pdf
    ...an alkaline 9V would only deliver about 8V in this circuit after approximately 12 hours use. Then 7V after 24 hours, etc.. A 100 ohm resistor is a good compromise between somewhat initially overdriving the LED and maintaining light output as the voltage falls off.
    p.s. "datasheep"??
    lol, that actually would be a good name for some product. I don't know what, but it's catchy.
    That is very awesome man, and even better given i have all the parts less than 1 meter away from me. Great work 5/5 -Duck
    how I am gona burn the le, when 9 volt batery dont have much ampers,and you see that the lamp works.
