I still have a small bag of bullet shells from when my brother asked me to make cufflinks for his wedding. I recently used one to make a flower. Here’s another try at making use of old shells.
I hammered the shell onto a socket bit and then mounted the socket into my drill press. I used a pipe cutter to remove the primer end. I then removed the primer itself and placed the piece of shell onto an earring backing. These backings can be bought at any craft store.
I took an air gun “BB” and hammered it flat just enough so it sat in the hole left from removing the primer. After it was all soldered in place I used a center punch to simulate a firing pin mark. I didn't use the original primer because I waned to keep contrast between the metals. Polishing the original primer removes the nickel plating and leaves behind a brass finish.
Use expended cartridges. That means bullets that has already been shot. Do not under any circumstances use live ammo.
Visit Our Store »
Go Pro Today »
I have .45 ACP (not yet in shop, you'll need to private message me), .270 Winchester, and Mosin Nagant 7.62 x 54 (Russian style rifle cartridge, copper color, see photo on Etsy shop)... oh! I also have some regular .22 LR brass.
Mrballeng... you're doing some really cool work! I've been making a few zipper pulls, with .45 cases, and cutting off the primer ends adding a small magnet to make a cool magnet for filing cabinet.
This is why I need to de-stash. Too much stuff.
I would love to see some sweety try wear these past the Mexican guards on the border. Think it'll pass? :)
But i don't own a gun or as far as i know don't know anyone who does. So how can i get hold of shells like these?
Mrballeng, what did you use to remove the primer? I've found that for the shells I have (anything from 9mm, .38, .45, 7.62, and .248), the hole is so small that the rods I'm using tend to bend before the primer is ejected. I've tried nails, solid metal (hubby swears they're steel) rods, and screws. Most tend to be too big in diameter and those that aren't bend or break. Haven't tried tempering them yet to see if that helps or just makes them too brittle. Any suggestions?
