9v Portable Mobile Charger
4,778
48
8
Posted
Introduction: 9v Portable Mobile Charger
hey guyzz...
i have made a portable charer for my mobile phone and thought should post it on instructables
theory`s apart,
lets get started
Step 1: MATERIAlS REQUIRED
this portable charger needs very less equipments
1.lm7805 ic (main component)
you can get it at any good electronic shop or on sites such as ebay
2.battery
any 5v to 9v battery,i used a nine volt
3.female usb port
you can buy it or can pluck out from a old died usb charger as i did
4.soldering machine and solder
use this if you want to make it permanent but it wil work whitout it
5.hot glue gun
i used it to stick the ic,battery clip and usb port together
6.battery clip
i had one lying around
7.bottle cap
i used it as a cover
Step 2: About Lm7805
it is an ic which converts 5-9v to 5v
the 1 line is for the +9v input, 2nd is for ground and third is for the output 5v (as given in the picture
Step 3: Connect the Devices
remove the centre two pins of the usb port
from the left two first one is the + and second one is ground(-)
Step 4: Connecting the Components
  1. connect the +ve of the battery to 1st pin of the ic
  2. connect the -ve of the battery to the ground of the ic
  3. connect the third pin of ic to the +ve data line of the usb port
  4. connect the ground (2nd) pin of the ic to the -ve of the usb port
Step 5: Finishing
set the device into the cap or in any covering which you want
it is very small then the normal charger and portable
if you have made the portable charger
ENJOY!!!!!
Step 6: Testing the Charger
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    8 Comments
    Most smart phone batteries are 1500-3300mah.
    A 9V battery has 50-400mah and at 500mw load has less than 300mah capacity.
    You're also losing 30% of that 300mah thru the 7805 as heat.
    Just exactly HOW much does this remaining 210mah charge your phone ???
    Ref : http://www.powerstream.com/9V-Alkaline-tests.htm
    It's a tiny and wonderful idea.
    what is the output ampere of this charger?is it stable ? and how can we know this will not hurt phone?
    Like the cap design!
    no u dont need a capacitor ,it will make it complicated to fit in a bottle cap but u can add one
    LM7805 work only with minimum 7 volt to input.......(max 20 volt input)....to give you a correct 5 volt output ....!!!
    if you have a high power battery it will work with 5v
    it is female usb port by mistake i have written it male
