3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A 5MP stereo-camera for pictures and movies!
This Instructable describes how to combine two normal cameras into one new stereo-camera that can even record movies!
To connect two cameras you need to open the camera and solder some small wires to all relevant pins. Then we apply a pinhead to the wires, fix it on the outside and connect the pinheads of both cameras via a cable so they act as one camera.
What you need is:
two identical cameras (may be old and cheap, I used two Concord5040, for 10€ each)
The simpler the better. Stereophotography works best if everything is the same except for the viewing angle.
thin copper wire (0.15mm diameter)
a solder iron with tin
two pinheads, number of pins depending on how much functions you want to synchronize
two jacks for the pinheads with cables
Mounting for two cameras
Step 1Open Camera and identify pins
So first you have to open the camera and identify the relevant pins.
All cameras I know have the case screwed on.
As the screws are very tiny and small, I advise you to work in some kind of box with a small rim. The top of a shoe box is ideal. If anything falls down accidentally it won't roll away and nothing is lost.
If the casing has different screws it is good to glue them successively to some clear tape in the sequence as you unscrew them. This way you can easily keep the track which screw belongs to which hole. I also used small dots beside the holes to identify the used holes.
You could also take some pictures during disassembling, to remember the steps.
11 comments
Nov 4, 2010. 9:03 AMWo0kiE says:
just curious as to how long it took you to figure this one out...
BRILLIANT!
I am gonna start looking for some cheap dig. cameras now!
Oct 13, 2010. 4:20 AMjekan777 says:
should try
May 7, 2010. 3:37 PMmadmanmoe64 says:
 If I found a two stage switch would it be possible to add a remote shutter release to the wires? So that I don't disturb the whole set up when I try to take a picture.
also do you have a link to where I could find those pin connectors, I'm sure I've tried Maplin (u.k electronics store) and can never find them.
May 7, 2010. 10:39 AMEmsaid says:
so do you have to wire them together? or could you just take the pictures at the same time. Also how do you put the two pics together
May 6, 2010. 1:28 PMkelseymh says:
What a great project!  Enough detail, with good macro pictures, so that someone with electronics experience should be able to do this with different cameras.
One question, though.  With the two cameras positioned as you show in Step 7, the focal distance will be different for each lens (offset by the thickness of a camera).  What effect does this have on the clarity of the stereo result?
May 7, 2010. 9:54 AMkelseymh says:
Thank you!  Mine has a mechanic focus (and zoom).  You're quite right that for a fixed focus, images at infinity will be the same, regardless of the small offset in distance.  And (unlike "close in" stereo) you don't have to deal with convergence effects; all the rays are parallel.
May 7, 2010. 7:47 AMrimar2000 says:
You can put the cameras in Z arrangement. There are many free programs to make 3D taking into account one cam is "topsy-turvy". That way you have both cam at same distance from the object. Your arrangement works, too, but for near objects the size difference of the images turns noticeable.
May 6, 2010. 9:46 AMBobS says:
Great work! You took the risk of ruining a camera, but you ended up with a flexible stereo solution.
One suggestion for dramatically enhanced stereo effects of far away objects (hyper-stereo- I did this with mountains and clouds): as you indicate, the further apart the cameras are, the smaller it all seems (doll houss effect).
For very large objects, like geological features, cloud structures or large bird/ fish flocks, hyperstereo reveals a completely hidden dimension, as normally, we have a single eyed view for these things. Hyper-stereo requires camera spacings of 1 to several 100s of meters. For astronomy: millions of kilometers to light years!!!
I found a single camera solution by using the fast motion of a train/ car/ airplane to take pics at the required spacing How to make 3D images of clouds
Making 2 adapters from your pin-outs to a network CAT5 cable socket (as found in any junk computer), would make it very simple to inter-space the cams to larger distances.
A few years ago I wanted to do this, but 2 identical digicams were really too expensive then (A $ 10 digicam is a really good deal even now I think!!! -For Holland...).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:andyk75
I like to explorer new things and try out stuff. At the moment I'm in to electronics and LEDs (mainly).
