3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Backyard Path that says "We're going Places"
A Backyard Path that says \"We\
Sometimes your backyard is just a litter box for a pet or a romping ground for a child.  Sometimes it's a place of tranquility that aids in releasing your your tensions after a long day of work.  Whatever your backyard is used for, Most people do something more with it than just let it be a mowing ground.
My wife and I live next to a park that is adjacent to our rear fence.  There are times when the weather makes the backyard less than desirable to walk through.  With a young child and frequent visits to the park, we decided to build a walkway.
A pathway is a great way to add value, both aesthetically and financially.  But it is your backyard.  Don't build a path that you will hate, you will regret or that doesn't make sense to you.  Now let's talk about what you'll need.
Step 1Tools, Tools, Tools,...some advil and a bed.
Regardless of the style of walkway you build, you will want the following:
Wheelbarrow
Shovel, Round Point
Gardener's shovel
Gloves
Mason Line
Stakes
Depending on the type of walkway you may need:
Hand Tamper
Hammer
Wood for forms, i.e. 2 x 4s
concrete mixer
Shovel, Landscapers
Sand Plate aka compactor
20 comments
Sep 22, 2011. 1:22 PMkenbob says:
Beautiful!
Mar 4, 2011. 7:25 AMAsmodeous says:
NIce work dude!
Nov 17, 2010. 9:29 PMtbcross says:
nice job I like the design :) great ible.
Nov 22, 2010. 2:20 PMmickeypop says:
Great work - love the pattern.
We built a flag stone version about 20 years ago.
Over time he stone "crawled" eventually needing some rework.
Here is a little trick i learned then.
When preping, mix concrete into the sand (DRY).
After placing all of the stone and checking it is all level,
just turn on the sprinkler for around 20 minutes to set it
Mostly dry cured concrete is always the best.
works great and no "crawl"
Nov 22, 2010. 7:20 AMemorning says:
First... Thanks for taking the time to write this up and take pictures. The picture of the edging and its position on top of the gravel/sand helped me understand this part of the process that I couldn't find elsewhere.
One question though... In the last photo of the completed path I see small triangular pavers along the edge. Did you buy those? Or did you have to cut those?
Nov 22, 2010. 5:16 AMShiseiji says:
Great!
FYI, any pin (vs. threaded) type fastener over 6" is generally considered a spike.
Love the pattern.
Nov 21, 2010. 3:56 PMpoorboy1 says:
Nice job on the path! The design is uniqie, I like that! I also like your tractor.
Nov 21, 2010. 7:03 AMFuzzyBearGeek says:
Wow. Beautiful pathway. The layout shows a nice combination of artistic talent combined with extreme handyman skills. Nicely done! Great Ins too.
Nov 21, 2010. 6:48 AMNotanexpert says:
I think the your title was similar to something I saw on the Sims, in the description for the flooring.
Oh and nice path
Nov 21, 2010. 6:45 AMkarlgabel2 says:
Nicely done! Great writeup and it looks great too!
Nov 18, 2010. 2:30 PMGreasetattoo says:
Nice...
How would one do a curved pathway?
Any idea?
Nov 19, 2010. 11:59 PMMinifig666 says:
I'd recommend ye olde technique of a spray can and a stick. Draw out your curve and then lay the bricks to conform to that shape. It would only work for shallow curves and the pattern probably couldn't be too intricate though.
If however you have a lot of time you could devide bricks into segments and lay them out to follow the curve as tightly as you need. It would get quite tedious though!
Nov 18, 2010. 10:44 AMkenbob says:
Beautiful and well documented. I love the pattern, how did you select/design it?
excellent instructable!
Nov 18, 2010. 5:42 AMnanosec12 says:
in a word:
Beautiful !!!
Nov 17, 2010. 9:49 PMChrysN says:
That looks great.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:Pkranger88
I am a Product Development Engineer manager for an OEM of Food Production Equipment in Overland Park, KS. In addition, I am a CATIA V5 instructor and a subject matter expert in Design processes, Des...
more »
