A BeagleBone Tutorial - Getting Started With Motor Bridge Cape
Published
Introduction: A BeagleBone Tutorial - Getting Started With Motor Bridge Cape
About: Howdy, we are application engineers in Seeed. Sharing projects with maker community is awesome. Hope you like it XD Seeed is the IoT hardware enabler providing services that empower IoT developers to swiftl...
This project is a tutorial which can teach you how to use the Motor Bridge Cape on BBB or BBG, and I’ll show you a demo that can drive six servos two DC motors and one Stepper motor at one time.
Step 1: About Motor Bridge Cape
The Motor Bridge Cape features bi-directional motor control using two TB6612FNG integrated dual H-bridge, so it can control two stepper motors or four brushed DC motors with 6~15V DC power and about 1A current draw per motor. The cape provides 5V regulated power to BBG or BBB with a max input voltage of 15V. It also has six servo control interface and six expand IO. All the features are provided by the on board STM32F0 coprocessor. The coprocessor can communicate with BeagleBone by I2C or UART interface.
By the time you’re done with the project you will reap the following experience:
  • Be familiar with BBG/BBB;
  • Be able to use Motor Bridge Cape.
Now, let’s get started.
Step 2: What Do We Need
Step 3: Hardware Overview
As the picture shows, the Motor Bridge Cape has a strong ability to drive motors. It’s very appropriate that you make an automation devices such as robots with it.
Step 4: Softdware Work
If this is your first time to use BBG, maybe you can follow this link to get started with your BBG trip.
I assume that you’re already familiar with the Cloud 9 IDE. You should create a new Python file such as motor.py
Input the following command in the terminal
$ git clone https://github.com/Seeed-Studio/MotorBridgeCapeforBBG_BBB
And then copy the code to “/var/lib/cloud9”
$ cp MotorBridgeCapeforBBG_BBB /var/lib/cloud
And open the “MotorBridgeTest.py” file
Run the code, and you’ll find the motor is beginning to turn.
If you want to know more info about Motor Brige Cape, please click here.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    Hi, I am using the motor bridge cape using BBB to run stepper motor. When I execute the test file, I end up in the error "Attribute error: 'Adafruit_I2C' object has no attribute 'writeList'". Kindly help me in this issue.
