A Better Cat Litter Sifter
80,308
134
23
Posted
Introduction: A Better Cat Litter Sifter
Pets Month
Second Prize in the
Pets Month
I have tried several different methods of cleaning my cats' litter box. From a three-piece sifting pan(messy), to a Littermaid automatic sifter(more trouble than it's worth), to an old-fashioned sieve-type scoop. The best method I have found is this sifting bucket of my own design. This is my first Instructable.
Step 1: Materials
For this Instructable, you will need the following materials:
Two nesting buckets I used the plastic containers that the Kitty Litter comes in.
Hardware cloth. This is available at any hardware store. I had some laying around with 1/2" spacing, but I would recommend using a finer mesh.
Two-part epoxy, or another suitable adhesive.
Step 2: Cut the Bottom Off One Bucket
Carefully mark a line around one bucket as a cutting guide using a pencil or felt-tip marker. The cut-line should not be too deep, so the pee clumps don't have too far to fall. I would make it shallower than this if I were to do it again. Cut using a sharp utility knife or your favourite power tool. If using a knife, BE VERY CAREFUL! The plastic is very tough, and the knife could easily slip out. Clean up any rough edges.
Step 3: Cut the Hardware Cloth
Take your bucket top and use it as a template for the hardware cloth. Leave an inch or so on each side. Snip each wire with side cutters or a dremel tool. Cut out each corner to match the corners of the bucket top, and bend these sides up.
Step 4: Assembling Bucket Top and Mesh
Press the mesh into the top part from the top and form it into the sides using a small hammer or mallet. Scuff the area of contact using coarse sandpaper so the adhesive will have something to grab onto. Mix up some epoxy and glue the mesh to the side of the top, and you're done.
Step 5: How to Use
Now all you have to do is place the bucket top into the other bucket and dump the entire contents of the litter box into it. Gently shake it to let the remaining "clean" litter fall off, and dump the nasty bits back into the litter box. Dump this into a litter receptacle, and replace the "clean" litter. It's best to use a premium litter, otherwise you will have to fight a giant cloud of litter dust.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    23 Comments
    Did the cats come up with this idea? They look very well read.
    I did something similar - get 2 big flexi tubs, drill a ton of holes in the bottom of one. Holes should be as large as possible, but not so large that the wood pellets just fall straight through (around 6mm). Put this bucket inside the other, but not all the way - find a way of raising it off the bottom of the other one by around about 5cm. Wood pellet litter falls through to the lower bucket when it gets wet, and some urine will go straight through. You will still need to scoop out the solids.
    Yess. This hits all of my requirements for a litter box, PLUS I only have to buy minimal supplies. Now I can have a deep box so they can't pee all the way to the bottom, without having to scoop, and I can still use my litter genie! Thank you! I'm going to make this tonight.
    Came up with same idea a couple years ago.. It works perfect!! I used smaller mesh chicken wire instead but makes cleaning box a snap.. Thanks for sharing
    We use wood pellets. Natural, don't produce dust, don't dye cats' paws pink, absorbent , cheap and they have a lively clean pine smell to them. And, they don't clump and glue to the bottom of the box. Win-win!
    Nice idea, not good to breathe the dust. I use a kitchen utensil called a spider and switched out the short wood handle for a long one. Works A1 on clumping litter. BTW, clumping litter is diatomaceous earth. I get a 44 lb bag for less than price of a large box with a pic of a kitty on it. Our automotive store carries it. It's a little courser but works well. Mechanics use this for oil spills as regular clay litter is too slippery.
    The cat on the left (poop factory #1) looks like it is planning to kill you when you aren't looking.
    This reminds me of panning for gems. Except it's for cat sh*t.
    I tried to stifle a laugh, but I failed
