Having recently built a 4x4x4 LED cube, I thought it might be interesting to apply the same techniques to building an LED Christmas tree. I used a single white LED as the 'star' and then a mix of red and green LEDs forming the sides. Initially I thought to make the tree star shaped in cross-section, but eventually realized that a six sided star would be easier as the supports could be made out of two identical triangles.
I used an Arduino to control the light patterns with a sketch loosely based on some sketches for a 3x3x3 LED cube.
What you are going to need:
1 medium white LED
15 diffused red LEDs
15 diffused green LEDs
6 resistors (values depend on the LEDs chosen, I used three 10 ohm and three 1k ohm)
some medium gauge copper wire
some fine gauge copper wire
an Arduino, I used a Freeduino
an Arduino compatable prototype shield
some male headers to attach the protoshield to the Arduino
Remove these ads by
Signing UpStep 1Building the frames
I then built a second identical triangle. The two triangles were soldered together to form a six sided star.
Four more stars were made similarly by decreasing the distance between the nails by about 1.3 cm per layer. The smallest layer was pretty tiny and I might try decreasing the amount of change per layer next time.
I have great respect for folk that build stuff like this - I never seem to have enough fingers, myself.
