Introduction: A Chocolate Chip Cookie Recipe Worth Trying
Picture of A Chocolate Chip Cookie Recipe Worth Trying
The contest here on instructables have played a huge part in challenging me to think outside the box and try to create different recipes. I have learned so much in the process. It has been this experience that has made me a better cook and it has produced failures along the way. In this case, it started out that way. Many people are making changes in their diets for a lot of different reasons. Modifying favorite recipes can be a good way to transition slowly into the diet of your choice. If I have not made a recipe before I will cut it into half the first time around just in case I don't like it. It has proved to be a good practice. I wanted to try a different chocolate along with the Hershey's and add a few different ingredients to change the flavor. I salted the tops of a few of the cookies with Kosher salt just for the fun of it. We liked it better without the salt but if I had used unsalted butter the Kosher salt might have been pretty tasty. I will make it with unsalted butter next time.
I purchased Hershey's chocolate chips and modified the recipe on the back of the package because I wanted to try to create a different twist to the recipe using different ingredients. This instructable will share my experience modifying their recipe and some experiences I had  while doing just that.
Let us get started!
Step 1: Ingredients and Utensils
Picture of Ingredients and Utensils
Recipe:
2 1/4 Cups all purpose flour
1/4 Cup Fine Almond flour
1 teaspoon Kosher salt plus a little extra to sprinkle over the top of the cookies
3/4 cup softened butter ( imported butter is superior for baking because of the flavor and flakier texture.  I could not find any here without driving an hour.) I have heard Trader Joe's sells good butter. Look for imported butter in the frozen food section of a store.
1/4 Cup Cream cheese
1/2 Cup Organic pure cane sugar
1 Cup Brown sugar organic would be even better
1 and 1/4 teaspoon Pure Vanilla Extract ( this makes a big difference in the flavor of the cookie dough.)
2 Large eggs( room temperature ) (farm fresh eggs are superior )
5 Squares of  Ghirardelli Dark
3/4 Package Hersey's Chocolate chips
Pam or parchment paper
Utensils:
Basic utensils such as measuring cups and spoons, mixing bowls, Mixer, spatula, cookie sheet, and oven.
Notes: these cookies are chewy. If you prefer a crisp cookie omit the brown sugar and use regular sugar. Because this recipe was altered from the original recipe I suggest baking two cookies to see how the dough will work for you. Slowly add more flour to the mixture a couple of tablespoons at a time. You need to add enough flour that the cookie mixture will be more like a bread dough (just not quite as dry as bread dough. I hope I explained that well enough.
Step 2: Measure Ingredients
Picture of Measure Ingredients
Measure the ingredients and cut the Chiradelli into small chunks a little larger than the chocolate chips.
Step 3: Cream Together
Picture of Cream Together
Cream together . . .
Butter, cane sugar, brown sugar, cream cheese, and vanilla.
Add eggs and mix until creamy.
Step 4: Mix Dry Ingredients
Picture of Mix Dry Ingredients
Thoroughly mix dry ingredients:
All purpose flour, almond flour,baking soda,and salt
Step 5: Add Flour to Sugar Mixture
Picture of Add Flour to Sugar Mixture
Either by hand or using a mixer, slowly add the flour mixture to the sugar mixture; mixing well.
Step 6: Add Chocolate Chips and Chirardelli
Picture of Add Chocolate Chips and Chirardelli
Add chocolate chips and Chirardelli chunks; gently stirring to mix well.
Step 7: Refrigerate
Picture of Refrigerate
The longer you refrigerate the cookies the better they are. My daughter could not wait 24 hours so we made them in 12.
Step 8: Drop Dough Onto Cookie Sheet
Picture of Drop Dough Onto Cookie Sheet
Pre-Heat Oven to 375 degrees F:
Oil the cookie sheet and drop the cookie dough onto the sheet at least 2 inches apart.
Bake approximately 10-12 minutes or until the edges begin to brown. Careful not to over bake them as they will
continue to cook when you remove them from the oven.
Step 9: Modifications to Recipe
Picture of Modifications to Recipe
Oh no! They did not turn out what do I do?
My first batch was very runny and a total disaster. They were very flat and over cooked.
When I made the batter I kind of thought it was too much like cake batter, but decided to bake a small batch anyway.
After seeing the results I decided to make 2 cookies by adding 1 1/2 teaspoons of regular flour to the mixture. I baked the two and they turned out perfect. I then added 1/4 cup of regular flour to the rest of the batter and it was the perfect solution. Using different flours can change the texture of the batter. I suggest when you modify a recipe;  bake a couple of cookies at a time to see how well they bake. I decided to use regular flour to the mixture because that is what the original recipe called for. Almond flour is not a true flour but rather a nut flour which is much courser than regular all purpose flour. That is why I chose to add  1/4th cup to the original recipe reducing the regular flour by 1/4th cup.
I changed the measurements to the ingredients page and wanted to mention altitude can be a factor in recipes. If your first 2 samples of  using 2 1/4 cups of all purpose flour and 1/4 cup of almond flour does not bake up nicely; then slowly add a couple of tablespoons of regular flour at a time  and baking 2 cookies at a time until you get the desired results. I say this because I had already baked 11 cookies before adding more flour.
Step 10: Sunshiine's Final Thoughts
Picture of Sunshiine's Final Thoughts
If by adding flour to this mixture had not worked ; I think I might have added some Crisco  to try and correct the problem because fat can make a big difference as well.
All of us liked this recipe. It was a chewy chocolatey cookie. I enjoyed tweaking an original recipe and the experience of correcting the batter to achieve a great tasting cookie! I hope you like this recipe as much as we did.
I wish to thank Instructables, our sponsors, contributors, and all my visitors for making this a great place to share. Thanks for stopping by and do have a safe and happy day!
sunshiine
Lovetra (author)2016-02-28
They are good! so is your sense of humor!
sunshiine (author)Lovetra2016-03-01
Hello Lovetra,Thanks for the compliment~ and for stopping by~ Hope your spring is filled with wonderful surprises~
sunshiine~
kbp555 (author)2014-11-16
Yum!
sunshiine (author)kbp5552014-12-02
Thanks!
sunshiine~
nerfrocketeer (author)2014-02-27
Wow, these look good! :D
sunshiine (author)nerfrocketeer2014-02-27
Aw thanks nerfrockerteer, they were very good. Thanks for checking them out and as always have a super day.
sunshiine
nerfrocketeer (author)sunshiine2014-02-28
You too! :D
sunshiine (author)nerfrocketeer2014-02-28
Thanks!
Tarun Upadhyaya (author)2014-02-25
If I could eat one thing right now after a heavy Indian Dinner, this would be it :). I bet it is so yummmy :)
+1 haha
sunshiine (author)hunter9992014-02-25
More in the oven after I post this!
hunter999 (author)sunshiine2014-02-25
Haha, I wish I lived near the Land of Enchantment! :D
You are close enough! Right out of the oven! They are better after 24 hours as you can see the difference! Enjoy!
hunter999 (author)sunshiine2014-02-26
Wow! They are awesome, the chocolate chips melted look so yummy! :D
*stomach rumbles*
Thanks for the (cyber) cookie sunshiine! :-)
sunshiine (author)hunter9992014-02-26
They were the best after 24 hours but it is hard to wait to bake them. Making 2 batches is the best way then you get nice fluffy ones that melt in your mouth! Glad you liked the cyber cookie.
sunshiine
Yeah, I might make these sometime! And I'll be sure to post a picture when I do! (favorited)
I hope you do! Thanks!
sunshiine
I almost died of temptation ;-)
Awesome, I hope you cleaned your monitor first. I will be experimenting with this recipe again and have some ideas! Stay tuned!
sunshiine
Ha ha :)
Guess what! I have been waiting to bake more to give the batter more time to soak up all the goodness. I am baking them after I post this, come on over but you better be quick they won't last long!
sunshiine
n33r (author)2014-02-25
Well i dont know about the cookies ( not allowed to eat eggs :( They look delicious though ) !!
But i loved that milk Mug's design !!! :P
sunshiine (author)n33r2014-02-25
Thanks . . . i guess I should modify this recipe so you can try them! The mug belongs to my daughter whom I am visiting. My hubby wanted me to bring it home after seeing the picture but I told him our daughter probably would not part with it. I thought it was the perfect mug for these cookies. thanks so much for commenting and I hope you find you a perfect mug!
sunshiine
n33r (author)sunshiine2014-02-25
That would be great if you can modify recipe :D !!
& mission find that kind of mug has begun, will let you know if any success :P !!!
I will be playing around with it again, I will probably work on it more when I get back home. Are eggs the only thing you can't eat from this recipe? Thanks for sharing!
sunshiine
BayRatt (author)2014-02-25
I think I would have eaten the cookie dough before it got to cookies. LOL!
sunshiine (author)BayRatt2014-02-25
I actually did that and it was very good. I did not eat a lot because of the raw egg, I am not that brave. Thanks for sharing and I hope you night shines!
sunshiine
lcole5 (author)2014-02-25
What does such a small amount of almond flour do for this recipe?
sunshiine (author)lcole52014-02-25
The purpose was to experiment using that flour because I had not used it before. I wanted to create a nutty flavor without adding chopped nuts. We did not notice the nutty flavor but I have used a small amount of coconut flour in a recipe and it was perfect for the recipe. The next time I will increase the amount of almond flour and reduce the regular flour and try to alter the recipe so I won't need to add regular flour. Unique flours are tricky to use when altering recipes or at least that has been my experience. I am learning along the way. Thanks for commenting and do have a great day!
sunshiine
hunter999 (author)2014-02-25
Awesome (as always) sunshiine! Keep it up :-)
Thanks hunter! Have a very w=sweet day!
sunshiine
No problem sunshiine and thanks so much - you are a very kind hearted person :-)
jessyratfink (author)2014-02-24
Oh my lord, I need these!!
sunshiine (author)jessyratfink2014-02-24
They were . . . .
yummy! It is always good to see you swing by with your kitty! Thanks so much for stopping by!
sunshiine
About This Instructable
7,739views
226favorites
License:
Bio: I am married with two children. Spring, summer, and fall are my very favorite times of the year. I love the sunshine thus the reason ... More »
More by sunshiine:How to Process Card and Dye Raw Wool Score Shape Color and Stencil Bread for Bread LoversCreative Pickled  Blueberry Recipe for Foodies
Add instructable to:
