A Collection of Easy Office Pranks
When I saw this contest, I knew I had to enter!  But which prank?  I have over the years witnessed and participated and researched thousands of pranks, from the simple to the extreme.  In my humble opinion, a good prank can be set up and excecuted quickly and effectively.  Sure, it would be funny to wallpaper someone's office with post-it notes, or fill their cubicle with packing peanuts, but who has the time or resources for that?  My favorite prank is the one where nobody is hurt or overly humiliated, and that everyone can enjoy a good laugh afterward.  I realized I couldn't narrow it down to just one.  Therefore, I am submitting my compilation of low-tech easy office pranks that are sure to annoy.  The computer based ones are factored off of Windows XP, and any other software may not work or require different steps.  Enjoy!
Step 1Prank 1: The Impossible Desktop
This one is amazing in it's simplicity to execute and the results it yields.  If you have access to your targets computer, it can be pulled off in about 1 minute if you're quick.  Here's how it goes down:
Step 1: From the regular desktop screen of the computer, press the "PrtScn" button on the keyboard.  This takes a snapshot, or screenprint, of what is on the screen at that moment.
Step 2:  Open Paint (Start > Accessories) and either select Edit > Paste, or press Ctrl + V to paste the screenshot into Paint.  Then choose File>Save As and call it anything, but change the file type to .jpg, and save it to the Desktop.
Step 3:  Close out of Paint, and back on the desktop, Right Click and create a new folder, of any name.  Set it to one edge.  Any icon on the desktop that doesn' t have a white square with an arrow is an actual file or program, and can be moved into this folder.  The rest are icons, which once you move into the folder need to be deleted off the desktop.  You can remove everything from the screen EXCEPT the Recycle Bin.
Step 4:  Right click on the Start/Taskbar, and uncheck "Lock the Taskbar" if it is checked.  Now, if you put your mouse over the top edge of the Start/Taskbar it'll turn into a double ended arrow.  Drag it down until there is no Start/Taskbar on the screen.
Step 5:  To finish up, right click on the now empty desktop, and set the screenprint picture you took to be the wallpaper and walk away.
The Result:  Your target will not suspect anything is wrong with their computer until they go to click on something.  Anything really.  The only responding icon on the desktop now is the Recycle Bin (if they try to move it, they may figure you out, but who ever messes with the Recycle Bin?).  Once you've had your laugh, and maybe taken a video, undo your damage before your mark loses it.
15 comments
Mar 22, 2010. 9:16 AMmarjorieallea says:
 Cool!   Heh heh heh....  actually that's a cool desktop even for myself...
Apr 8, 2010. 5:57 PMKing Julien says:
yep
Apr 8, 2010. 6:58 AMSaturn V says:
If they have a laptop, just close the lid and then take a picture.
Mar 20, 2010. 7:41 AMHamatoKameko says:
"Regular" cola won't work; they tried it on Mythbusters. It's something in the Diet Coke that reacts with the Mentos.
Apr 8, 2010. 6:52 AMSaturn V says:
It's the artifital sweetener in the Diet Coke and nucleation cites in the mentos.
Mar 31, 2010. 6:57 PMColiflower says:
 Wow!  Great list!
Mar 25, 2010. 10:05 PMlukeea says:
You don't need both -r and -s commands. Keep -r if you want the computer to restart or -s if you want it to shutdown. This is pretty funny. I've had the shortcut link to something else such as paint or solitaire, but I never thought of using the shutdown command. Good work.
Mar 19, 2010. 6:01 PMstargazer418 says:
A simpler way to do this is to just right-click the desktop, go to the View -> menu, and uncheck Show Desktop Icons. Then set the wallpaper as you said.
Mar 23, 2010. 3:33 AMRaNDoMLeiGH says:
hey, I never knew you could do that! muhahahahahahaha!!!!!1!!!!
Mar 23, 2010. 12:36 PMdavmaldo says:
also, you should make it so the task bar auto hides so even that is useless
Mar 19, 2010. 6:43 AMKozz says:
I'd like to add an easy one to this list.  For Windows users, try the key combination CTRL+ALT+(arrow key) where the arrow key is your desired desktop orientation/direction.
So try CTRL+ALT+(DOWN/LEFT/RIGHT) to make things more interesting.  (CTRL+ALT+UP will correct it.)
This is a simple, harmless and completely reversible prank to pull on those IT co-workers who ought to know better to lock their console when they walk away from their desk!
Side-note:  If you have multiple monitors, this key combo only changes the orientation of the display where your mouse cursor resides, so if you want to turn primary & secondary upside down, you'll have to do the key combo once for each.
Mar 19, 2010. 7:49 AMHuntman00 says:
what does it do?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:ludionis
