Introduction: A Complete Idiot's Guide to Make LED Light Unit for Planted Aquarium
Please have a look at my website for more tutorials and fishy pictures: www.playsofrays.com
As always I am writing this for people who have no prior experience with LEDs, electrical and electronics works just like I never had before I did this. I will be posting a lot of pictures here and going into a lot of detail about making connections, wiring etc. So the people who know how these things are done may find it boring and unnecessary, but please bear with me.. it’s for the newbies.
In order to understand LEDs and what kind best serves your needs go to my previous post – An Idiot's guide to understand LEDs
It contains all the theoretical aspects of LEDs and in very simple language. Once you have a good understanding of what you need, read this post.
Before starting this thread I would like to thank Milad, who helped me a lot throughout this tedious process. He is an awesome guy.
I ordered the following things for Lighting from LEDGroupBuy.com:
12V 5A Power supply w/4PIN molex connector
4 pin Molex to 3 pin fan
80mm Fan Silencer
Arctic Alumina Thermal Adhesive 5g
Arctic Silver Céramique 2 - 25g
CREE LED Optics / Lens
(LED Type: CREE XT-E / XP-G / XP-E, Optic Angle: 60, Quantity in Package: 6 Pack)
(LED Type: CREE XM-L, Optic Angle: 60, Quantity in Package: 6 Pack)
CREE XM-L White
(Color: Cool White (~6500K), Group: T5, Quantity in Package: Single LED)
XML-CW-T5-3 Nos
CREE XP-E Red
(Quantity in Package: Single LED)
XPE-RED-2 Nos
CREE XT-E Royal Blue
XTE -ROYAL BLUE- 4 Nos
CREE XT-E White
(Color: Neutral White (4500K), Quantity in Package: 6 Pack (5% discount))
XTE-NW-6PK- 1 (6 Nos LEDs)
CREE XT-E White
(Color: Warm White (3250K), Quantity in Package: Single LED)
XTE-Warm White- 3 Nos
DIM4 - 4 Port LED Sunrise/Sunset Controller V1.0
DIM4-R1.0- 1 Nos
Fan 80mm- 1 Nos
Hanging Kit for MakersLED Heatsink- 1 Nos
Inventronics 40w driver - 700mA
MakersLED Designer Heatsink Kit - Professional Grade (Length: 12 inch)
Ocean Coral White (Optic Angle: 90°)- 2 Nos
OEM Digital Multimeter DT-830B- 1 Nos
Solder Tube 10g - 2 Nos
Soldering Iron 60w- 1 Nos
Solid Wire 24awg (300 volt) - 25 feet - Black- 1 Nos.
Stranded Wire 24awg (300 volt) - 25 feet - Black
Then I got some more stuff from Home Depot –
assorted grommets
zip ties
water proof cable connectors
two pin plugs
some timers
extra wire (in case needed)
Before starting,
make sure to make a rough sketch of how you would assemble your LEDs on the Heat sink. It is very helpful to refer to it when making the circuit. Without it there will definitely be a lot of confusion and chaos. A blueprint of this is available on LEDgroupBuy.com- Blueprint
And here is mine for reference in the pictures.
Step 1: Testing the LEDs
For testing I ordered a Multi-meter from LEDGroupBuy.com. Connect the red and black wires (with pins on the end) to the multi-meter body as shown in the picture. Now turn the knob to point to (diode) symbol as shown in the picture.
Gently touch Red wire pin to positive and black-wire pin to negative of the LED you are testing as shown in the picture. If there are no defects on the LED, it should light up.
In case the LED doesn’t light up, check the connections to the multi-meter again and whether its knob points to symbol.
An alternative way of testing (without the multi-meter) is to use two AA size batteries and connect the positive of the batteries to positive plate and negative of the batteries to negative plate of the LEDs.
Step 2: Preparing the Heat Sink.
Step 3: Positioning the LEDs on the Heat Sink
Step 4: Pretin the LEDs and the Wires.
• Heat your soldering iron. When it’s hot gently bring it in contact with one end of the soldering wire. The soldering wire immediately melts leaving a drop on the hot tip of the iron. Gently place this drop on the small connecting plates of the LED you are connecting. Let it cool. It takes about 3-5 seconds to cool off. Do this for all the LEDs. Do the same for all your wires.
Step 5: Soldering the Wires to LEDs
• For this bring the hot tip of the soldering iron in contact with the pre-tinned connection plate of an LED very briefly. This will melt the shiny tin layer. As soon as this happens hold the wire with a pair of tweezers and gently push its end into the melted metal and let it cool. Once cool, it holds the wire firmly. As you make connections for each LED you can test them with the multi-meter or a battery as mentioned earlier. Repeat for all LEDs.
Pretin your wires too and then can solder them to the LEDs. This connection is considered as more reliable.
Step 6: Connecting the LEDs to Driver
• Out of 20 LEDs, 15 are connected to an LED Driver (I have used Inventronics 40W driver – 700 mA) An LED driver converts AC to DC on which all LEDs run.
The driver has 3 sets of connections – AC in (2wires - black and white), DC out (2 wires – red+ and black-) and Dimming Controls (3 wires – green -, purple+ and yellow x).
Two wires positive+ and negative – of the dimming control on the LED driver will go to a channel of DIM4.
In case of this particular driver, purple is positive, green is negative and yellow is not used anywhere. Remember it like this – purple – P- positive; green-is mean-hence negative and yellow-is a dirty fellow- therefore not used.
•3 Royal Blue LEDs are powered by Channel 1 of DIM 4 Circuit.
•One OCW (ocean coral white) is connected to Channel 2 of DIM4
•One OCW to Channel3 of DIM4.
For people who are not using DIM4 circuit can connect all the LEDs to the LED driver and they are good to go.
Step 7: Putting the Optics on the LEDs
** Sometimes, the Optics wont fit the LEDs. In that case just file the inner side of the square slot of optics and then put them on the LED. It'll fit. If you put the optics imbalanced, the light beam will be imbalanced too. So try putting the optic perfectly stable on the LED.
Step 8: Finishing the Heat Sink With Fan, Splash Guard and Other Attachments
Step 9: Lets Talk Dimmers and Drivers
Each of the channels of the DIM4 is capable of lighting up to 3 LEDs and 0,1 or more drivers. Let’s consider two cases here –
• CASE I : Using DIM4 to control Drivers that are connected to LEDs:
Each channel of DIM4 can control dimming options of at least one driver. In this case DIM4 will command the Driver to dim, giving the sunrise and sunset effects. If DIM4 is connected to drivers, it will require only 500mA current.
• Case II : Using DIM4 to control LEDs directly (no LED driver):
Each channel of DIM4 can light up exactly 3 LEDs at a time. DIM4 will directly command all LEDs to give the sunrise-sunset effect. If all LEDs are connected directly to DIM4, it will require more current – (I've used 5A). Hence you will need to use – THIS
• My Case:
I have used –
i) Channel 1 for my LED Driver. This driver lights up 15 LEDs.
ii) Channel2 for OCW1 (Ocean Coral White), which is a set of 3 LEDs of color red, blue and green.
iii) Channel3 for OCW2 which again is a set of 3 LEDs – red, blue and green
iv) Channel4 for 3 Royal Blue LEDs.
• Relays: There are two relays R1 and R2 in the circuit. Relay R1 fires up as soon as Channel 1 goes live and Relay R2 fires when Channel3 goes live. Both relays give a power supply of 12V. Now these relays may be used to control your fans. I used R1 to start my fan which sits on top of theheat sink. As soon as my Channel1 goes live, it controls my LED driver connected to 15 LEDs; at the same time, relay R1 fires, turning on the fan over the heat sink to cool down the heat sink.
Step 10: Putting the Driver and DIM4 in a Box
Step 11: Cover All the Connections
Step 12: Installing the Hanging Kit
Step 13: A Special Note About OCW LED (Ocean Coral White LED)
DO NOT DO THAT.
OCW (Ocean Coral White) has already been soldered in series. You DO NOT have to connect it in the series.
THE PROPER WAY IS THIS- (The second picture)
Step 14: Disclaimer
Thank you for reading and watching It was a Superman presentation (never mind, lol).
Step 15: Replacing "so Many" Red Colored Wires
Its the wire which we use for connecting Computer monitor to CPU. It has 15 pins.
I cut the female part out-
Step 16:
Although this DIY has many things that a beginner can learn and make an LED unit which can be used anywhere- Kitchen, Hallway, decorative purpose. But 'this' very light is to be used in my planted aquarium. It will grow live aquatic plants in an aquarium.
Step 17: After a Year: Still Going Strong
Wow..
108,768 views. I feel proud that I wrote this instructible.
So I just wanted to show you all what I am doing with my light after a year or so. I have dismantled my planted tank and have started a Tanganyikan sandy shore biotope in it.
And guess what, fishes just love the sunrise and sunset effect. They are breeding like rabbits.
Here are 2 videos of the tank. Hope you'd enjoy them.
