There's a double switch plate with 2 horizontally operating flip switches that control the shop lights as well as the kitchen light. It's mounted next to the door in the usual place, but the oversized refrigerator covers all traces of it.
Since I'm in the shop several times a day, I have to poke my finger behind the refrigerator to flip the switch. I have to be extremely careful how I pull my finger back out. Being in a hurry, I often lever my finger between the switch and the refrigerator... And let me tell you, it hurts!
No wonder I become paranoid whenever I head to the shop.
Now, I've solved the problem with my new 3D printer.
Remove these ads by
Signing UpStep 1: Print & Assemble
The faceplate isn't rafted to keep the exposed surface as shiny as possible and because of that, the shallow countersink for the attachment screw is unsupported and will be a little rough. A quick twist with a drill cleans it up nicely.
The handle is designed to be attached with a #4 screw. 3D printers normally print holes smaller than designed, so I decided to open the receiving boss in the handle with a drill as well. If you're using a low durameter plastic, you may not need to do this.
The handle and slide have an alignment tab that keeps everything centered and squared.
Once you have the parts, slip the handle ends of the slides through the slots in the plate and rotate them into position, snapping the guides into the rails underneath. They should move smoothly with no wobble. If not, file the parts so they slide freely.
Next, screw the handles onto the outside faces of the slides. If needed, use a shim to raise the handle up enough to slide over the surface of the mounting plate.
You'll notice a couple of rectangular tabs underneath the plate. Our wall is painted blue and I like the fact that I can easily see if the light is on. If I see blue, it's off. If you don't like the color of your walls, or just want a white or fire red slot, cut a thin (.020" or so) piece of plastic or stiff paper to fit the area defined by the tabs and paste it to the plate before screwing it to the electrical box.
Remove the old plate and replace it with the new one.
Wa-La... No more bruised or broken fingers. :)
Visit Our Store »
Go Pro Today »
Zapp
The first two require the involvement of a beutiful person.:)
Thanks for the entertainment,
Off for Thanksgiving with little else to do,
Zapp
Zapp
Yah, I live about an hour from you up the coast. Ole' Sherman never made it to Savannah, so Antebellum housing is rampant (but pretty) around here.
I don't think all the problems ended in the 1950s... Our house was built in the 80s and both the plumbing (slab) and wiring (attic rat's nest) are a mess. I don't know if I'd trade for plaster & lathe issues, but I might be persuaded:)
Referring to your previous post, I'm a big fan of X-10 stuff and use it to control the things I can't easily access, like shed lights.
Also, if you amortize the cost of a 3D printer for everything that can be made, it's a decent way to make items that either don't exist or cost a fortune. For example, my classic British race car was made with 1960s "hi tech" components. For weight, several interior parts were vacuum formed. They lasted for about 10 years before the plastic outgassed and disintegrated. I could easily buy a new, vacuum formed instrument binicle for $35, plus shipping from England, but I could also design my own and print it for less than $5 (http://www.thingiverse.com/thing:33034). I chose to print. Not only did I have the chance to design it "my way", but it cost less, is made from ABS, and I could get it "now". Add that up with all the other items I've been making and the cost of the printer will be covered in no time.
The printer has become a valuable tool in my shop. I think of it as the perfect employee... I tell it what to do and it does it. I only have to check up on it once in a while to make sure its not goofing off (power outages seem to make it unhappy). Now, instead of me making parts the old way, the machine makes them while I do other things... It doesn't ask for a break, it doesn't try to make conversation and I don't have to ask how it's weekend was. :)
Can't live without it now... Its become one of those things like electric toothbrushes and GPSs. Once you use them, you can't go back.
Very impressive! How'd you do it?
Zappenfusen
What materials aside of various plastics, metal's(?), are available to print with? I'm fascinated with the future of 3d printers but size limits, materials, and programming requirements have relegated my curiosity to a wait and see attitude. Do you print positives for molding purposes? The "in 50 years" everyone will require one if only to purchase the CAD files for a new toothbrush I can believe, it's the size limitations I can't understand. The online photo's of the Eiffel Tower, which appear amazing, ain't much when the reveal is 3" tall. I could greatly simplify my Christmas list if my Kid's, Wife, etc. would accept very small gifts which appears to be the limit with consumer model printers as I surely can't afford the Mega-bucks for the industrial version. Heck, I'm having serious problems attempting to learn Arduino programming, much less CAD. Main subject of wordy reply is How do you make stuff bigger than 4"X4" on a consumer model 3D printer? Yes, that S.O.B. who's name shall not be spoken spared my hometown and most of the period homes avoided demolition in the 50s only after the idiots tore down City Market, gazed upon an empty Ellis Square and experiencing emotions they were unaware they possessed realized "We fuXked up". I am semi-retired, as far as the City of Savannah knows, but retain my State Master Electrician certification allowing me to continue servicing my older, preferred customers most of whom are NOGS (North of Gaston Street) a label referring to Historic, Gen. Oglethorpe designed Savannah. I've made a living almost entirely in Historic homes which at most were piped for gas and undoubtedly largely built by slaves, by hand, with the most intricate details you can imagine. The ability to reproduce plaster crown moldings, mantle details, etc., etc. would be fantastic. In the past the labor required to e.g. file a profile knife for plaster crown molding reproduction places the cost in the realm of the true Southerner's and the Carpetbaggers who can afford the grand old houses. I understand your enthusiasm for the printers. If I could replicate one of a kind details I've been required to cut, maim, deface, in order to electrify the Antebellum homes I've made a specialty of and avoid hours of making said sacrileges disappear I'd purchase immediately. Please explain 3D printers ability to duplicate a 20' section of base molding while reducing the cost from astronomical to a cost which would allow me an heretofore profit based on guilt to a mark-up satisfying to the customer as well as MySelf. Also if you would prefer avoiding long winded reply's from a person who greatly misses the old fashioned mailed "Letter", Run,Run, as fast as you can for you've replied to just such a nut.
Thanks for any enlightenment,
Zappenfusen
• Overview: 3D isn't quite ready for casual home use. The concept is old and the technology to transmit has probably been around since the 1960s or 70s using fax machines to send shapes that were cut out, stacked and glued together to form an object. A number of other methods are competing to become the standard, but so far, thermally extruded plastic is leading the race to home appliance status.
Materials: The most popular are made to use ABS or PLA. Virtually any thermally softening material that can be sent through the extruders at around 300ºF or less, including wax and chocolate can be used. Other industries have been experimenting with other types of materials including "printing" houses in concrete. Metal can also be extruded, but the higher the heat requirement, the larger and more expensive the equipment needs to be.
Another tool that may be better for you is a laser cutter. The bad news is, at the moment, cutting steel heavy enough to make blades for a shaper (for your molding) would cost you $300,000.
A CNC (computer controlled) milling machine is another choice. Milling isn't an "additive" process like printing is, but it's precise and would allow you to make nearly anything a 3D printer can without the small size limitation. A mill can also make tools that would allow you to create those architectural features you mentioned. Harbor Freight sells a decent mill for $2K, what I paid for my printer, but you could probably find a used one for less. Low cost mills aren't CNC, but they can be made into one (as I said, 3D isn't ready for home use). In order to convert the machine, you'll have to be creative, but if you're already messing around with Arduino, you're halfway there.
• Christmas gifts? Check out my puzzle http://www.instructables.com/id/A-Diabolical-Puzzle/ I think you might get rolling eyes if the kids saw gifts made on your printer though.
• 50 years? More like 20. I'm fully retired. I was an engineer, inventor and futurist. 3D printing today is probably akin to what the automotive industry was before the model A. It's a disruptive technology that's slowly growing in popularity as it is becoming better and cheaper. Right now, the materials it uses are pretty much limited to those I've listed. But we know that every material is made up of the same stuff... Atoms. And we're beginning to learn how to control materials at the atomic level, so eventually, we'll be able to "create" materials at will. And once we can do that, we can do this:
Imagine sitting in front of your computer surfing through Amazon looking for a gift for your wife. You come across a bottle of Channel #8 (future, remember) and decide that's what you'll give her. The price is $258 (I may have miscalculated for inflation, but feel free to add another zero:)
You go to PayPal and send the money. Then, to your download folder, where you un-stuff the file that was just delivered to you. You send the new file over to your 3D "maker", which is about the size of a microwave oven, and, in about 15 minutes you open the door and pull out the bottle of perfume.
Now, you say you want a bumper for your car. No way will it fit into that microwave sized thing. So, like the perfume, you order it online, only you have the file sent to the UPS (U Print Stuff) store. Get into your car, head over to the Oglethorpe Mall, where you pick it up for a small fee of $21,347.
• Making things bigger: My printer's table is 6" x 9" and most of the things I print fit on it. If I need something larger, I'll make multiple pieces and chemically weld them together (ABS welds extremely well using a slurry made from ABS and acetone). Some people like to make snap-fit shapes, but that's a lot of work to get right.
• CAD: Download SketchUp. It's simple. I teach the 4th and 5th graders I mentor how to use it in about an hour... Or go to a site like http://www.thingiverse.com/ and download what you need from there.
It isn't perfect and it requires multiple steps to transfer the proper stl files, but AutoDesk 123D >http://www.123dapp.com/< will let you print anything you can take pictures of.
All of these things, including the printers, are experimental. The software is free and the printers' build sizes are going up while their price is coming down. Eventually, they'll be like inkjet printers, where they sell them at cost and make their profit on selling the plastic.
• 20' of molding?... A 3 head shaper machine can't be beat.
• What did I miss? I'm tired. I'm going to bed:)
Nice to hear from you (seriously).
bfk
Thanks bfk,
Zapp
You could also extend garage light switch leg to new device box in garage and install motion switch negating physical access to existing switch and turning garage light on upon entry to Garage. I'm retired with 30 years of electrical problem solving and can confuse any problem to the extent that most customers allowed me tremendous leeway, trust, and confidence that in the end, my solution would be safe, conveniently usable, and require no "Call Backs". Many "solutions" meet code, few meet the unwritten convenience factor!
I doubt that there are many switches of this type out there, with the problem we have of being hidden behind something. :-/
