Step 6Extend the Floor Shelf brackets.
Here's how I extended the 24" brackets to 32": Wooden reinforcement.
I used a drill press to drill 2 holes through the 1x2 and the shelf bracket at the same time so they'd match up. Carriage bolts attached the two together. (the square part of the carriage bolt sinks into the wood)
Water resistance precautions: before assembling each extension bracket, paint the wood with the same exterior-grade paint you used on the walls. (you DID paint the walls, right? RIGHT?) I also covered the top of the bracket with tape. In the past, these brackets proved to be prone to rust on the inside, so I sealed them off with the same tape I sealed the gutters to the wall with. I almost filled them with expansion foam, but I already had the tape.
Add Comment
