3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Get Smart Style Cone Of Silence
Step 4Assemble the Domes
Assemble the Domes
Progressively assemble the domes by taking two segments and lining them up.
Then push a pin through a some point on the tab on both and wiggle it around a bit to make the hole a bit bigger. This makes it easier to push the split pin through, which is the next thing to do. Spread the split pin once through so that it doesn't fall out.
Repeat this step every so often along the tabs.
Note that when you join the upper and lower parts of the tabs, that this will automatically cause the flat segment to bend in where the taper changes.
Now repeat this process until your fingers get sore and you have recursively joined all the dome segments to make two domes with no roof.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:gardners
