Introduction: A Get Smart Style Shoe Phone (gen 2)
This real working shoe phone, with the phone in one shoe and the bluetooth headset in the other, was the basis of a Flinders University press release, on The New Inventors and a headline item on the ABC South Australian TV News:
It was also used in a couple of dozen radio interviews which were conducted by shoe phone, including this one. You can find more details at http://realshoephone.com
It will be informative to review the instructable for my first shoe phone if you want to make this one, but not necessary.
Step 1: Buy Yourself a Nice Pair of Shoes
The most important characteristic for the shoes is that they have an old style wooden heel, or at least one that is removable, since that is an option too.
It is also helpful if the sole is reasonably robust.
Step 2: Get a Suitable Mobile Phone and Bluetooth Headset.
Now, this shoe phone works by having a bluetooth headset in one shoe, and a mobile phone in the other. The reason for this is that when you see a mobile phone in the shoe when opened, it kind of ruins the magic of it being a shoe phone, rather than just a piece of consumer electronics wedged into a shoe.
I used a Motorola V620, since it has an external antenna. This makes it easier if you end up with a metalic lid on the heel, since a phone with an internal antenna would probably be too shielded to operate.
The V620 works fairly well, but with two annoying caveats: (1) it doesn't do bluetooth if you put a 64KB SIM in (took a while to figure that out); and (2) when on bluetooth you can't use a custom ring tone, instead it always uses the default ring tone. This was a bit disappointing, because it feels like a shoe phone should have a real telephone type ring tone. On the upside, it does voice dialing, which means you can ring out from the bluetooth shoe. Anyway, enough analysis of the V620.
As for bluetooth headsets, I used a Motorola H500, the same as I did with my first shoe phone. The H500 proved itself to be a good basis for a shoe phone.
Step 3: Prepare the Hollow Heels
This is the relatively complicated bit.
Remove the existing heels, and replace them will hollow compartments, that use studs to help the lits lock on.
The heel can be made from three pieces of wood that form the sides and rear of the heel. A small piece of wood or metal can then be used to mostly close the front of the compartment, leaving enough room for the telephone antenna or headset charger as appropriate.
A screw in one corner of the heel through a sheet of aluminium works satisfactorily. You can then use contact cement to glue a thin rubber sheet over the metal after you have screwed it into the heel.
Embedding studs into the wood and metal so that when it is being stood on, it cant open or rotate.
Then a clasp on the side of the heel and welded to the metal lid (this is where using steel would make it easier than aluminium, so you don't have to have to worry about oxidation) is all you need to allow it to stay shut when you walk around.
A permanent pen works well to reduce the visibility of the clasp.
Now, I cheated a fair bit here, by using the services of a family friend who is a cobbler, who had a ball of a time working on it. I can heartily recommend this method. But if you have to do it yourself, and are handy with tools, you shouldn't have too much trouble.
Either way, make sure that you make the compartment sufficiently big enough to fit the phone of your choice. I'd recommend allowing a few extra millimetres in the vertical direction, because the lid has a habit of bending inwards over time, especially if you use fairly thin aluminium like I did.
Some padding is probably a good idea to avoid unnecessary scratching. You might need to cut some notches in the padding if you use a phone like the V620 that has buttons on the outside, otherwise it might press buttons while you walk. (This happened to me early on, with the result that my shoe left a message on my mobile phone, and would have made any spy service proud with the way it picked up the conversations around me. Of course, pretty much this trick has been used by the KGB since the 1950s.
Step 4: Install the Electronics and Test.
All that is left to do is to assemble it, by putting the phone in one shoe, and the blue tooth headset in the other. I used some PETG plastic sheet and a thumb tack to wedge the H500 into the shoe.
If you haven't already, you can watch the video of the TV item where they show me using it.
I'll also endeavour to upload some more images when I get the chance.
