A Great Build-at-home Disc Golf Target (or a better use for 55-gal drums!)
Welcome to another outstanding Instructable from Kentucky Bum! In this Instructable I will show you how to build a kick-ass disc golf target. I have seen numerous plans (and even some for sale) but I didn’t care for any of them; too hooky, too flimsy, not robust enough, not weather-proof enough or just poorly designed. None of the parts in most any of these plans are ‘cheap’ by any standard, but if you are going to put something up outside, leave it there and expect to survive against the weather and a never-ending assault of hard, plastic discs it has to have some mass to it. If it has mass, it’s gonna cost you (KB axiom #28).
A commercial ‘portable’ target that fits in bag cost $120, a commercial semi-permanent one (all metal with a 4-legged base) will cost $175 and a pro version is gonna cost you about $400. Here’s my version of the ultimate home disc golf target. It should cost you about $95 to $100 per target (and take you about 4-man hours to build) but it should last you a long, long time.
 One more note, with the exception of the outer diameter of the ‘basket’ (made from the 55-gallon drum) this target is pretty close to the target specifications shown on the PDGA.com website. For an ‘approved’ target the diameters for the basket should be 24.5” to 27.5”, but most drums are only 23 ½” in diameter, so these will be a bit ‘tight’ for the basket, however it should make you a better ‘golfer’; your practice target should always be a little tougher than a real one anyway.
Here is a picture of my second basket which I put up last weekend. It is made from a barrel that has a bonded on top and bottom. It looks much, much better.
Step 1What you will need
Here’s an exploded drawing of all of the components with dimensions (minus the chains). You may wish to print it out and refer to it while you assemble this target.
Here’s what you’ll need:
·         1 ea plastic 55-gallon drum ($10 to $40 depending on location and patience)
·         3 ea PVC 3” Closet Flanges ($2.50 to $4.50 depending on design; but buy the cheapest); these are the large circular flanges that you bolt toilet seats down to, so you know they are strong.
·         3 ea PVC 3” to 2” step down bushing (~$2.50 ea). These allow you to bond a 2” PVC pipe into a 3” Closet Flange.
·         63” of 2” PVC Schedule 40 pipe (the thick stuff, not the thin stuff); I buy the 10’ pipe (for about $5.50 ea) two at a time; they will make 1 ½ targets each so you will get 3 targets for the $11 worth of pipe.
·         31’ of 2/0 chain Passing Link (usually about $1.14/ft) OR 3 ea 10’ boxes of the same chain (I’ll tell you why I use 30’ and why I don’t use Straight Link chain below)
·         15 ea #60 S-Hooks (~$3 a bag for 6)
·         1 ea 3” diameter hinged binder ring (Office Depot sells these for $1.50 each). This is to gather the chains around the center tube. You can use a large twisty tie or even some bailing wire to do this as well, but it doesn’t look as cool. You can also use a large nylon zip tie, but they don’t last long being exposed to the weather so plan on finding that 3” ring someday.
·         4 ea ¼ - 20 x 1 ½“ Carriage bolts
·         4 ea ¼ - 20 x 2” hex-head bolts
·         8 ea ¼ - 20 nuts
·         8 ea ¼“ flat washers
·         8 ea ¼” lock washers
·         PVC cement (glue)
·         1 ea bag of Redi-mix concrete cement; usually less than $3/bag for one 80# bag which will do two holes or just buy a 40# bag for each hole (a bit more usually).
Here’s the tools you’ll need:
  • Saws; preferably a chop saw and a table saw. These are to cut the PVC pipe and 55-gallon plastic drum with.
  • Drill w/ 2 different sized drill bits: ¼” and 13/64” (a 7/16” can be substituted for the 13/64” if you don’t have one).
  • 7/16” wrench (or socket set with that socket). A socket driver for your drill would be best.
  • Grinder w/composite blade (to cut chain), bench vice and hammer (to split chain). You can use a reciprocating saw with a bi-metal bit or a hack saw too, but it may take you a while…
Target dwg.pdf(612x792) 21 KB
41 comments
1-40 of 41next »
Jun 5, 2011. 7:33 AMzigzagchris says:
Lucky to have a nice course around your house. I teach discgolf at my camp and its so much fun.
Jun 7, 2011. 2:56 PMzigzagchris says:
Lucky, up in new england it is not as well known. Out side my camp iv only been able to find one course nearby and it was not in the best of shape...
Oct 13, 2010. 3:09 PMDikkaD says:
Some other forums have suggested using a X-mas tree stand to hold it up or an umbrella rack. I think I am going to do mine in a cement tire tho because Im not planning on moving it around to far/much but want to have the option to do so (Its heavier therefore more stable). Thanks KB for keeping me busy!
Oct 14, 2010. 8:43 AMDikkaD says:
That would not work for my situation as I am wheeling it across the street to a small park. I am looking in to using some sort of stand, possibly with a way to temporally anchor it to the ground. Anything to get my mid range game better!!
Aug 10, 2010. 7:11 PMWestyii says:
AWESOME !!! Built this today after work. Took me just about 2 1/2 hours. The Instructions are spot on, had to play around a little with the chain spacing because I forgot to pick up the sewing gadget you mentioned. I took a video from my cell phone and plan to post the final on YouTube. I will be sure to thank you for your creativity. Oh and instead of sinking the pole, I was able to make it a portable basket by slipping the PVC pole over an old work light stand. You can find these pretty cheap at yard sales and salvage or surplus stores, you can see it in the video. It fit perfect, without any modifications! It did raise the height of my basket from 24" to about 27" but that';s ok with me. Thanks again A+ build, now to test it out tomorrow!!!! woo-hoo!
Jul 29, 2010. 11:50 AMCaptain Molo says:
i never saw it, but how long are each strands of chain?
Jun 24, 2010. 12:59 PMpie popper says:
i was wondering what is the diameter of this, and what is the diameter of an official basket
Jun 7, 2010. 6:10 PMbrees1525 says:
As far as chain cutting goes. It looks like you used thicker chain than regulation. You should use 2/0 straight link coil chain. And the 2/0 chain is easy as hell to cut with bolt cutters. I used crappy 20 dollar bolt cutters from Walmart to cut my chain and it was pretty dang easy. Also you should use 2 layers of chain, 12 outside and 6 inside.
May 19, 2010. 7:13 AM8lbhammerhead says:
has anyone heard of bolt cutters? much quieter,safer and quicker for cutting chains.
Mar 20, 2010. 2:18 AMBard says:
 For portability, Ive noticed that portable basket ball hoops have a can that you can add water to weight it down. Would it be possible to attach these targets to something like that to make it portable then just fill it with water when you get it to where your going?
Mar 18, 2010. 11:38 AMSureShot says:
Very cool Instructable! I really like the white and red one. The only thing that could make it even sweeter would be a lite weight, yet sturdy, movable base! How cool would that be! You could set up anywhere. Good job and thanks! Here comes spring and this project is going to the top of my list.
Mar 19, 2010. 7:05 AMSureShot says:
I just got 3 barrels for 30 bucks delivered! Man I love craigslist!
Mar 18, 2010. 8:24 PMMarsh says:
 Nicely done!
Mar 18, 2010. 8:08 AMdougistre says:
Have you thought about cementing pipe in the ground so you could move the basket to other locations? Say put 1-2 ft of pipe in the ground and then slide the PVC pipe in the pipe in the ground? Just a thought so you could change your shot.
Mar 18, 2010. 11:13 AMdougistre says:
My bad, I didn't read the entire instructable. After my comment I saw where you had the removable post. As far as the 4 directions, you can have as many holes per basket as you have tee boxes. I really like your instructable and will be following your lead. Good luck with your baskets and your 9 hole course. May the Disc Gods look down on you when you shoot and say WOW what a shot!!!!!!!! Enjoy....
Mar 18, 2010. 12:47 PMdougistre says:
I didn't see the =8-0! on my screen, so I don't have any idea. Congrates to your wife, Now show her how it's done. Ha Ha.... Good Luck.
Mar 18, 2010. 12:00 PMW.A. says:
Well done!  Have have looked into making targets for home and never quite could find the right materials.  I will be using this instructable very shortly and will likely make a PVC base so that it is transportable.
Where is a good source to find these barrels?
Mar 18, 2010. 12:32 PMCovo says:
 I agree...the "tone pole" in my back yard ain't cuttin' it!!!
you might try Craig's List for the barrels.  Not sure where you are from but i did a search in SF Bay Area and I got 3-4 sources within a 1/2 hour from my house (south bay).
Mar 18, 2010. 8:04 AMJerryMopar says:
And for ultimate DIY, you could make the chains out of poptabs!
Mar 17, 2010. 9:46 PMusLEDsupply says:
I just sent the link for this to the guys on my ultimate frisbee team- I bet one of them will try to make it!!!  Thanks for sharing :-)
Mar 10, 2010. 5:36 PMzigzagchris says:
Just putting it out discgolf is the best sport DiscOvered
Mar 10, 2010. 2:05 PMonrust says:
Blue barrels Rock!
Mar 10, 2010. 11:38 AMsweetsabin81 says:
going to make one of these! Thanks for the great idea!
Mar 10, 2010. 9:33 AMkissiltur says:
Having bought one of the designs for a disc golf basket, I think I like your design better! The one I have is pretty authentic in its look, but the basket and top are made of plastic landscape edging which is too shallow really. It took a lot more than four hours to put together, too - lots of cable ties and hose clamps, along with fiddly work with chicken wire.
Here's a picture of the completed basket -
Mar 10, 2010. 5:20 AMblam72 says:
Fantastic design and well written instructions!  Years ago I had a portable target that was ok, but the overall quality was poor.  This one looks like it would last a long time.  I might have to add this to my spring project list.  Thanks for sharing.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:Kentucky-bum(EV World)
A jack of all trades and a master of many; I was the Sr R&D Engineer and Manager of R&D for a very large company, but now I am consutling on my own. I can truly say 'been there, done that', but I can...
more »
