Remove these ads by
Signing UpStep 1What you will need
Here’s what you’ll need:
· 1 ea plastic 55-gallon drum ($10 to $40 depending on location and patience)
· 3 ea PVC 3” Closet Flanges ($2.50 to $4.50 depending on design; but buy the cheapest); these are the large circular flanges that you bolt toilet seats down to, so you know they are strong.
· 3 ea PVC 3” to 2” step down bushing (~$2.50 ea). These allow you to bond a 2” PVC pipe into a 3” Closet Flange.
· 63” of 2” PVC Schedule 40 pipe (the thick stuff, not the thin stuff); I buy the 10’ pipe (for about $5.50 ea) two at a time; they will make 1 ½ targets each so you will get 3 targets for the $11 worth of pipe.
· 31’ of 2/0 chain Passing Link (usually about $1.14/ft) OR 3 ea 10’ boxes of the same chain (I’ll tell you why I use 30’ and why I don’t use Straight Link chain below)
· 15 ea #60 S-Hooks (~$3 a bag for 6)
· 1 ea 3” diameter hinged binder ring (Office Depot sells these for $1.50 each). This is to gather the chains around the center tube. You can use a large twisty tie or even some bailing wire to do this as well, but it doesn’t look as cool. You can also use a large nylon zip tie, but they don’t last long being exposed to the weather so plan on finding that 3” ring someday.
· 4 ea ¼ - 20 x 1 ½“ Carriage bolts
· 4 ea ¼ - 20 x 2” hex-head bolts
· 8 ea ¼ - 20 nuts
· 8 ea ¼“ flat washers
· 8 ea ¼” lock washers
· PVC cement (glue)
· 1 ea bag of Redi-mix concrete cement; usually less than $3/bag for one 80# bag which will do two holes or just buy a 40# bag for each hole (a bit more usually).
Here’s the tools you’ll need:
- Saws; preferably a chop saw and a table saw. These are to cut the PVC pipe and 55-gallon plastic drum with.
- Drill w/ 2 different sized drill bits: ¼” and 13/64” (a 7/16” can be substituted for the 13/64” if you don’t have one).
- 7/16” wrench (or socket set with that socket). A socket driver for your drill would be best.
- Grinder w/composite blade (to cut chain), bench vice and hammer (to split chain). You can use a reciprocating saw with a bi-metal bit or a hack saw too, but it may take you a while…
Target dwg.pdf(612x792) 21 KB| « Previous Step | Download PDFView All Steps | Next Step » |
PS Have you tried to cut 30-45 links of chain non-stop with a bolt cutter? Without a really big one it will flat wear you out. (That's the 'lazy' part of me talkin'...)
I couldn't come up with a good idea for a light weight yet sturdy portable base; that's why I figured cement holes were cheap and easy to put up in multiple locations if you only wanted to build one target. There is a 'portable' target you can buy for $175, and as far as the basket is concerned it's a good target, but the base is just 4 bent wire legs, but no matter how you hit it they are just not very sturdy and the target moves quite a bit on a hard shot. If you want to make this thing portable I recommend you make your cement hole in an old car tire (like how the old teether-ball posts were mounted years ago). It should be steady enough for even the most direct of hits, but you can roll it around the yard easy enough without lifting it :-)
I didn't see the =8-0! on my screen, so I don't have any idea. Congrates to your wife, Now show her how it's done. Ha Ha.... Good Luck.
Where is a good source to find these barrels?
you might try Craig's List for the barrels. Not sure where you are from but i did a search in SF Bay Area and I got 3-4 sources within a 1/2 hour from my house (south bay).
Here's a picture of the completed basket -
Thanks for the feedback :-)
