Step 6Step 5, Assembly
Step 5: Finally! Assembly!
· Bond two of the 2” to 3” bushings on each end of the 27” piece of PVC pipe and one on the end of the 36” PVC pipe. Goop up the inside of the bushings with a little PVC glue and push them down on the ends good and hard (to seat them completely). DON’T goof this up because [as any plumber will tell you] once you set two pieces of PVC together with that glue there ain’t no getting them apart…ever.
· Now, bond up only two of the Closet Flanges, one at each end of the 27” long PVC pipe. Make sure you get them completely seated on the bushing. If you don’t the gap between the top and basket will be off. Refer to the picture here; it should look like this.
· Don’t bond up the last Closet Flange; it will go on the one end of the 36” long pipe (with the bushing on it) but not for some time.
· A few minutes after you bond up both ends of the 27” PVC tube you can bolt one end of it up to the inside of the ‘top’ using the carriage bolts. Start the bolts on the top of the ‘top’ (upper side) so they are just buttons on the top. Use a flat washer, a lock-washer and a nut to secure the Closet Flange to the top from the inside. As you draw the nuts tight the carriage bolts will sink in to the softer plastic drum and keep the head will from turning as you tighten each bolt down. Tighten them down enough to draw the drum and the flange tight together without any gaps between them.
· Now place the other flange on the 27” pipe down in the bottom of the basket and push the 4 hex-head bolts though the flange and the base of the basket. They may be a bit tight, so you can use a power-driver with a 7/16” socket head on them to drive them thorough. Drive them as far though as you can without chewing up your rugs or carpet. It may help to rest the basket across a couple of 2x4’s.
Add Comment
