3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Great Build-at-home Disc Golf Target (or a better use for 55-gal drums!)
Step 8Step 7, Set it up
Step 7, Set it up
Step 7: Set it up! You can do one of two things here, the choice is yours:
1.       Put the 36” post in the cement hole in the ground and just snug the target down on top of the 2” to 3” bushing. It may take a little pounding on the top of the target to get it to seat all of the way down, but this setup allows you to pull the target out of the ground and then remove the post from the bottom of the target (although it may be real tight).
2.       Put the 36” post in the base of the basket first. To do this lay the target over slowly on it’s side (a few chains may fall off the S-Hooks but you can hang them right back up) and put a little PVC cement in the bore of the Closet Flange [attached to the underside of the basket] and glue the 36” post into it before you drop it in the hole in the ground. If you do it this way you may need to ‘tap’ the bushing in flush to the Closet Flange. Use a small piece of 2x4 [wood] on cut the end of the pipe; you don’t want to bugger up this end as it needs to slip into that cement hole and come back out again.
I did it like #2 because I have no need to dismantle them after I put them in. I also did it this way because I suspect that the bonded method will last longer and the target will be a bit stiffer at impact from the disc, but that’s just the engineer in me speaking out loud.
Last, if you really want to perfect this design, hang another 6 each 24” long chains from some eye-bolts from up inside the top evenly spaced on an 8” diameter circle (just outside the edges of the Closet Flange up underneath there). Use another 3” ring on the bottom to secure them around the inner post. It will add another $17 or so to the cost of the target but the design can easily handle it. You can always add them later if you want. That’s up to you.
Any questions? Just ask! I’m sure that I might have missed something that I thought to be obvious, so the only stupid question is the one you don’t ask.
8 comments
Oct 13, 2010. 3:09 PMDikkaD says:
Some other forums have suggested using a X-mas tree stand to hold it up or an umbrella rack. I think I am going to do mine in a cement tire tho because Im not planning on moving it around to far/much but want to have the option to do so (Its heavier therefore more stable). Thanks KB for keeping me busy!
Oct 14, 2010. 8:43 AMDikkaD says:
That would not work for my situation as I am wheeling it across the street to a small park. I am looking in to using some sort of stand, possibly with a way to temporally anchor it to the ground. Anything to get my mid range game better!!
Mar 20, 2010. 2:18 AMBard says:
 For portability, Ive noticed that portable basket ball hoops have a can that you can add water to weight it down. Would it be possible to attach these targets to something like that to make it portable then just fill it with water when you get it to where your going?
Mar 18, 2010. 11:38 AMSureShot says:
Very cool Instructable! I really like the white and red one. The only thing that could make it even sweeter would be a lite weight, yet sturdy, movable base! How cool would that be! You could set up anywhere. Good job and thanks! Here comes spring and this project is going to the top of my list.
Mar 19, 2010. 7:05 AMSureShot says:
I just got 3 barrels for 30 bucks delivered! Man I love craigslist!
Mar 18, 2010. 12:00 PMW.A. says:
Well done!  Have have looked into making targets for home and never quite could find the right materials.  I will be using this instructable very shortly and will likely make a PVC base so that it is transportable.
Where is a good source to find these barrels?
Mar 18, 2010. 12:32 PMCovo says:
 I agree...the "tone pole" in my back yard ain't cuttin' it!!!
you might try Craig's List for the barrels.  Not sure where you are from but i did a search in SF Bay Area and I got 3-4 sources within a 1/2 hour from my house (south bay).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:Kentucky-bum(EV World)
A jack of all trades and a master of many; I was the Sr R&D Engineer and Manager of R&D for a very large company, but now I am consutling on my own. I can truly say 'been there, done that', but I can...
more »
