A Knot Board for the cabin or den
 by dstoudt70
Reminiscent of Scout camp or the week in a Northwoods cabin is a knot board.  It is nothing more than a display of knots attached to a board.   While it is not difficult to make, it can be frustrating for the "knot challenged".  Learning to whip a rope and tie the knots may be totally new to you but there are plenty of web sites that will show you how to do it.
Materials
3/8" sisal rope
1/2" sisal rope
1" x 6" x 18" board (new lumber, salvaged or rough cut) For a 3 knot board.
1" x 10" x 18" board (new lumber, salvaged or rough cut)  For a 5-6 knot board.
1" wire nails
Light brown string-not thread
Picture hanging materials
      2 screw eyes
      picture hanger wire
Varnish or stain and cleanup materials (optional)
3/8" wooden dowel
Wood glue
Tools
Saw
Knife
Hammer
Paint brush
Drill
3/8" drill bit
Rasp or sanding block
Pen or marker
Step 1: Preparing the wood and learning to whip a rope
Cut the board to length and remove any rough edges using the rasp or sanding block.  Use plywood if you want.  My boards are both 18" long.  Use a 6" wide board for 3 knots or a 10" board for 5 or 6 knots.  Cut a piece of 3/8" dowel for each knot that will need one.  These include the clove hitch, the taut line hitch and the two half-hitch knots.  Use a rasp or sanding block to smooth the exposed cut end of the dowels and to add a taper to the circumference to make it look better.
Stain or varnish, if you want, and let dry completely.
Since you will whip the cut end of each end piece of rope you use, this is the time to learn how to do it.  Refer to this site to learn how: http://www.arklowseascouts.ie/resources/whipping.pdf
Attach the 1/2" rope around the perimeter of the board.  To start, position the whipped end at the middle of the lower edge of the board and attach it using a wire nail.  Drive the nail through the rope and tap the head so that it is just hidden.  Continue attaching the rope around the outside edge of the board, using nails every 3-4".  Use nails closer at the corners.  Stop nailing just after making the 4th corner.  Determine how much more rope will be needed to just reach the middle starting point.  Mark the rope.  Whip the rope on both sides of the mark and then cut it cleanly at the mark  using a sharp knife.  (I find whipping twice and then cutting is easier than cutting and then whipping.  Your choice.)  Start back at the corner and finish nailing the rope into place.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
