When kids in grade 6 walk into the woodshop for the first time they have already heard about the project from their siblings and are SO excited to get started.
So here are my learning objectives:
-The students will learn to creatively solve a problem within a set of guidelines.
-The students will learn to measure, apply the measurements and create a cutlist
-The students will learn to safely use a drill press and a scroll saw.
-The students will learn to effectively learn to glue.
Materials:
-1/4" square graph paper.
-carbon paper
-3/8" MDF 8.5" by 11"
-1/4" wood strips 3/4" by about 3' per student
-Glue
-Masking tape
-7/16" steel ball bearing. (per student) You can get these from electric motor rebuild places or just look under bearings in the 'pages.
Tools:
-Pencil, ruler
-12" Forstner bit
-Scroll saw
-Sanding board. (or just plain 120G paper sheets)
Submitted by HD Stafford Middle School for the Instructables Sponsorship Program
Remove these ads by
Signing UpStep 1: Starting the Design
I goto the board and start drawing a big rectangle than ask for where a start and finish should be. Than i ask the kids to describe paths from start to finish... the catch is the line can't touch or cross. Often i'll get kids to come up and draw paths as well. Eventually i guide them to a design thats interesting but not too twisty. They all say "thats TOO EASY!!" so i ask them to make it tricky by adding holes... They quickly figure out that holes placed in the right spots.... at the end of long runs or on the outside of a curve or in a way that makes the ball have to curve back and forth... make it tricky. Than i ask HOW we're going to make sure the ball follows the path... The kids figure out that walls will control the ball.
I set them all up with pages and say that i want 4 different paths with walls and holes all quick sketched in 20 minutes. They freak out and ask for more time. I say "NO WAY!" and yell GO!!! They love that its kind of a race...
This gets their brains going.
At the end of the 20 minutes (or whatever they need... i fudge it...) i say to stop and give them rules... i write them on the board...
Choose 1 and use the graph paper to draw it.
-All up/down and left /right. No angles. (tough to build)
-The ball takes up a space of 4 squares. So do the holes. This means that they must allow space for the ball to roll around the holes.
-The walls take up 1 square wide. The kids have to allow room for the walls.
-You have to allow at least 3 squares wide in between walls.
I than get the kids to start a rough but accurate drawing of the path.
They than add the walls roughly. check out the pictures...
Visit Our Store »
Go Pro Today »
I tried marbles but had a tough time finding ones with consistent sizes and shape... they would tend to roll all weirdly around the maze. Where did you get yours?
Thinking about trying your gumball machine next. Your plan seems to be easier to build than most. My biggest problem is my small budget...so I have to carefully select projects that are not budget-busters.
The gumball machine is REALLY popular with the kids. They love it. If you keep your eyes open the 4x4 stuff gets thrown out often. If you find the Jars and lids buy as much as you can because they are seasonal. Often they can be found at Thrift stores for next to nothing! I can relate to the budget thing. 2 years ago we lost 14 staff due to "cutbacks"... our province doesn't seem to value kids much. Real shame. Be sure to send pics when the gumball machines are done!
-stu
thanks for the feedback!
-stu
