3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Microsoft PowerPoint Quiz
Have you ever played The Impossible Quiz by Splapp-Me-Do? I have, and I wanted to make a quiz like it. Sadly, it is a flash file, and I cannot afford a flash maker. However, I figured out how to make a quiz using Microsoft PowerPoint nearly as good as the flash. If you read this Instructable, you can too! If you don't know how to use PowerPoint, I'm sorry, but it's not very hard. I use 2010 PowerPoint, but 2007 and 2003 are similar. All you need to know are how to use Action Buttons. Clicking on the link below ("The Not-So-Impossible Quiz") will let you download the first version of my own quiz. The Not-So-Impossible Quiz 2 is the newer, better version of the quiz made with PowerPoint 2010 (though it works with other versions). PLEASE DOWNLOAD THE FONT TRANSISTOR 2.15 FOR THE BEST QUIZ EXPERIENCE. Enjoy!
Step 1The Title Slides
The Title Slides
1.) First, type something like "start" in the middle of the first slide. You can use WordArt if you want.
2.) Go to Insert and then Shape (or Slide Show in 2003 and 07) and choose Action Buttons, and then Custom.
3.) Draw a shape around the word like I did in the picture. You can color it.
4.) Click the action button, and then go to Action under the Insert tab (or just right click on the shape and click Hyperlink).
5.) Add a hyperlink to the "next slide".
6.) Go to Slide Transitions, and check off both of the boxes so the slide doesn't advance on mouse click or after a certain amount of time. Do this to every slide you make! Don't forget!
9 comments
Feb 10, 2010. 12:38 PMlemonie says:
You can upload PPT files the same as images - can you add yours? If so you're best saving as an older PP format so more people can open it.
L
Feb 13, 2010. 1:06 AMlemonie says:
Oh well you could upload a new version? Thanks for looking. You should be able to upload the file to the Instructable in the same way as the pictures.
L
Feb 14, 2010. 11:41 AMlemonie says:
Oh well, the best I could suggest is some kind of zip compression. Whether it's any good for your presentation or not I've attached an old version of Winzip.
(It was free when I downloaded it years ago)
L
Feb 16, 2010. 2:30 PMlemonie says:
There doesn't seem to be a correct answer to 3, and (bearing in mind this is supposed to be hard) I don't get the 4 holes in a Polo mint?
L
Feb 16, 2010. 11:23 PMlemonie says:
Ah, puzzle & quiz - thanks.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:saintjimmy
