The photo shows the miter box I made for my circular saw. In the photo I am testing it with some 1 x 2 furring strip. In use the saw slides across a table with the saw shoe against a fence. See the next step for a Google Sketch-Up view of the miter box.
Remove these ads by
Signing UpStep 1: An overview image
Materials
- 1/2 inch plywood
- Finish nails
- Glue
- Screws
- Table saw
- Rule
- Square
- Hammer
- "C" clamps
- Hole saw
Visit Our Store »
Go Pro Today »
Awesome job on this though!
John
I continue to use epoxy because my only attempt to use wood putty did not turn out nearly as well as with the epoxy. In fact I just completed a repair on a tombstone vase. Half of the bottom piece was missing and I made it by using a file since it was much too heavy to mount on a lathe. It actually turned out well. I should have taken pictures.
Couple of questions:
What software did you use for the overview image?
How do you see to cut to a precise line, as you need to do when cutting moulding?
I have a neat hand miter saw that I found in the trash and rebuilt. Would be glad to make it available to you, especially if your son's houste is an hour drive north of your shop.
The overview image was done in Google Sketch-Up. If you have not used it, it is free and there are quite a number of video tutorials. I do not use it enough to learn and remember more than a few very, very basic things.
I can turn the miter box upside down so I can match cut marks scored on the molding with the path the saw blade will follow. I can also shine a flashlight through the opening made by the blade to align the marks on the molding. And, I could cut the molding a quarter inch or so long, turn the miter box over and compare the mark on the molding with the actual cut, then move the molding slightly, clamp it, and make the final cut.
I am sure there are little modifications I will make after more experience using it. I am already thinking of a couple of ways to support the end of the molding near the saw blade. One would be a pedestal that would elevate the miter box a small fraction of an inch. It would be just enough to support the end of the molding by the weight of the miter box. I have also thought about a 1/2 inch dowel that would cross between the sides of the miter box near the end to be cut. I would use a thin shim or two between the dowel and the molding to make the molding secure.
We will be driving to my son's house in Idaho on Friday. Thank you for the offer of a traditional miter box. I actually need two pieces of molding to make a total length of six or seven inches. For that I will likely need to buy an eight foot piece, so I can make quite a few mistakes until I get it right.
Don't know how much you are into woodworking, you might check this Instructable (of mine) on sharpening http://www.instructables.com/id/How-to-sharpen-your-woodworking-tools-with-sandpap/
Both sides of your workpiece should turn out fairly smooth since it is well supported by the "zero clearance" slot through the box.
One last thing, marking the angle you want to cut is great advice. I have cut many, many unmarked pieces in the wrong direction.
Not only are the cuts smooth, especially with a 40 tooth carbide tipped blade, but pushing the saw slowly will make for a smoother and better cut.
I have had the same problem you mentioned. I get confused and cut my last, barely long enough, piece in the wrong direction. I always mark the cuts on miters to reduce greatly the number of times I cut the wrong way.
I think you could make a version of this miter box that does not tilt the saw away from its normal 90 degree cut, but uses a fence designed to hold the work vertically on the work piece's edge and the fence is at an angle of about 7 degrees relative to the cut line of the saw. The saw would ride over the top of the fence with guides to keep it cutting in a straight line. The width of the piece to be cut would be limited by the depth of cut offered by the blade. I can try to make a graphic if this is not clear.
We're probably saying the same thing, just using different words. Po-tay-to, po-tah-to.
