3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A More Annoying Noise Maker (Version 1.0)
Anything is possible with the 555 Timer IC. You can pick one up from Radio shack and all of a sudden a whole range of new micro projects open up. Most of which make lights flash or make noise....annoying noise......very annoying noise. It is for that application most people buy a 555 Timer, to annoy someone! In this Instructable I will show you how to build " A More Annoying Noise Maker". Using this circuit you will be able to not only make annoying noises, but be able to change the pitch and tone using two variable resistors. So in theory we are really creating a really cheap, annoying, cool noise generator. So lets get started!
Materials
555 Timer IC
Variable Resistors or a Adjustable Power Resistor, you will need two (your choice, choose one with only two pins if possible)
0.1 uF capacitor, you will need two (the ID number on the side is 104)
100 uF Capacitor
A speaker around 4 ohms to 16 ohms
A regular switch
solder
wire
9 Volt battery
a 9 volt battery clip
& A project box / case
Step 1Building the Circuit
Follow the diagram provided at the bottom. if you wire every thing together and remember your polarity and connect every thing to the right pins on the IC you should be set to test it out. Once completed the circuit (if fitted with a small speaker) can fit into a mint tin or another small case. FYI: The fourth pin on the IC is not used in this project.
Circuit Diagram Legend
C1: 0.1 uF Capacitor (marked "104")
C2: 0.1 uF Capacitor (marked "104")
C3: 100 uF Capacitior
Spk 1: Speaker of your choice
Sw 1: On/Off Switch
+/- 9 volts: 9 volt battery Terminals
REMEMBER TO CHECK THE POLARITY!
43 comments
1-40 of 43next »
Apr 8, 2011. 10:31 PMtafelice says:
very nice instructable. Haven't built it yet, but I believe I can. No mention was made of the volume. Is it full volume or variable. How can you get more volume. Thanks again.
Apr 8, 2010. 5:24 AMjj123 says:
What about pin 7? Those arrows on the diagram dont really make it clear.
Jan 9, 2010. 1:34 AMnumenius says:
I made this as a first electronic  project to build and learn from and it's worked great. **Thanks for featuring this build** - I've tried other projects(with no luck)  and this is the first one I've had success with and have learned a little about the 555 in the process. So thank you for that.  Now I'm going to try fixed value resistors to set it to permanent tone/rate before turning it loose on the world! (also 2  variable resistors are too expensive to lose - or at least here in the UK - though it's also set me to thinking of starting to recover these from old equipment being thrown away) Can anyone who has made this make comment on how long it would last with a button cell?
May 10, 2009. 2:46 PMPyro Fiend says:
Wow, Tytanium had my same questions. Didn't see that. Sorry for taking up space in your comment box for repetition. But can I use a 8 Ohm Speaker, because these are extremely common? But seriously, THANK YOU TXTCLA55!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I LOVE this Instructable. I haven't attempted to build it yet because I just found it but this is cool and simple and hopefully easy. I just am not an experienced solderer because I don't own a soldering gun so I will have to use my schools as I don't have any bread board. Ah, well. THANKS AGAIN!!!!!!!!!!!!!!!!!!!
Oct 24, 2009. 5:19 PMadnimo says:
 provided you don't exceed 200ma of current (you'll burn the ic if not).
May 10, 2009. 2:40 PMPyro Fiend says:
Can this thing go to high frequencies? If not, how can I change the values of the resistors and/or capacitors to make it really high frequency? Your instructable ROCKS!!!!!!!!!!!!!!!!! I'm not kidding. Beautiful diagram. Simple too. And you use commonly available parts, no Igntion Coils or Plasma Pulse Tube Resonator Thingers in sight! Oh, and if I use a variable resistor with three prongs, which ones do I use? Can I use a photoelectric cell (aka photo resistor)?
Oct 24, 2009. 5:16 PMadnimo says:
 actually you should always connect the 3, two of them provide full resistance and the other one is for the wiper, low resistance will always proveil but in the case of a failing whiper, your circuit won't fail, it'll just work at the maximum rated resistance for that specific variable resistor.
Jul 31, 2009. 12:46 PMbigdeee says:
Great generator! I've actualy been looking for a 555/556 tone generator more along these lines. Thanks for posting.
Jul 12, 2009. 7:28 PMUnit042 says:
Not to be snooty, but the capacitor's (C3) bottom side was drawn upside down. The curls should be going downward.....
May 24, 2009. 6:55 AMPyro Fiend says:
Luckily, pretty much every resistor I own ends in a gold band, but some have five bands. However, for the HIGHER FREQUENCIES, what is the BEST resistance value? Thank you!
May 25, 2009. 4:41 AMPyro Fiend says:
Thank you for the help. Just one thing I don't get. HOW low should the resistors be? I feel kind of stupid, but is low resistance 100 ohms? Or is is 10K? OR it 220 ohms? Or is it 1K? I don't understand HOW LOW is low. If I use 100 Ohms, will it be inaudible to all humans, or will it just be a high-toned beep? Will it be 17 Hz so that some humans hear it and others don't??????????????? I feel like I am being annoying, but I am not good at soldering and I don't have a soldering gun (i use my schools) and I can't retake the circuit apart. Thank you!!!!!!!!!!!!!!!!!!!!!!!!!
May 27, 2009. 2:14 AMPyro Fiend says:
Alright, GOT IT!!!!!!!!!!! THANKS!!!!!!!!!!! YOU ROCK!!!!!!!!!!!!!!!!!!!!!
May 10, 2009. 2:47 PMPyro Fiend says:
Please help me, though. I am not sure about the High Frequencies because I have never used 555 timer ICs before and I just bought two of them. If you know how to get to high frequencies, I would LOVE it if you would tell me. Thanks!!!!
May 18, 2009. 5:17 AMPyro Fiend says:
Hold on. How do I know if my Photoresistor is low resistance. The label says: NSL - 4950 9840. I don't know what this means. Can I use a standard resistor instead of a variable resistor of some sort so that I know it is low resistance? And how low is low? Do you mean 100 ohms, or 10K, or something else? Please Help Me!
May 24, 2009. 6:53 AMPyro Fiend says:
Wait a second. I'm still confused. If I use two 5K resistors (5,000 Ohms) then I can get High Frequency Sound? Or do I need lower resistors than that to get the High Frequency? Also, can I use higher Capacitors than 0.1uF, or will that lower the sound more? Usually the less capacity, the higher the sound, and the more capacity, the lower the sound, but it might be different with 555 timer ICs. How low is low with the resistors to get really high frequency (i want about 16-20 Hz, if that helps you answer my questions)? Please Help Me! THANKS!!!!!!!!!!!!!!!!!!!
May 10, 2009. 2:50 PMPyro Fiend says:
How do you get your instructables to appear online? I can't get mine to show up when I enter Key Words.
May 10, 2009. 2:49 PMPyro Fiend says:
Tytanium, Capacitors aren't rated in "k", you know that right? I think the value is in Micro Farads. That's what I've read.
May 2, 2009. 11:31 PMTytanium says:
Would there by any chance be an alternate rated type of cap that i can use beside .01uf?
May 3, 2009. 3:12 PMTytanium says:
I forgot to mention that I tried putting some 2 pin variable resistors instead and still cant get a sound other then a really low hum even with adjustments made with a screw driver.I have tried a few different 555's (NE555) ,not quite sure what else to try but i will get some pictures of the build and the exact components that i have used.I am thinking now that maybe i have just been unlucky and the components are dead.
May 3, 2009. 5:46 AMTytanium says:
Also all i can get is a low hum from the speaker that is only audible when you put it right up to your ear... I have no idea what could be wrong, i must have made a mistake somewhere but i just can't find it.
May 4, 2009. 11:32 PMTytanium says:
The only other variable resistors that i can find have anywhere between 3-6 pins.. Could i possible see a picture of the type that you used?.
May 5, 2009. 10:17 PMTytanium says:
Thanks, I saw that before i think.What is the range that those variable resistors are capable of?. Even when i use just plain resistors i still don't achieve sound.
May 1, 2009. 9:15 PMTytanium says:
Hmm still having no luck.
May 1, 2009. 7:50 AMTytanium says:
Hey this thing is pretty cool and i would love to use it to be annoying.I tried to build one but i could not get it to work.I followed the schematic the way that i understood it but was unsuccessful.I had a bunch of parts laying around which is what i used.For the variable resistors i used potentiometers(i liked the fact that they use a knob) that i got out of some salvage electronics that i keep around for the components.The potentiometers that i used have 3 pins, i don't own a multimeter so i took a guess and tested them separately using a battery and an led in a simple circuit and managed to dim/brighten the led.Unfortunately when i added the potentiometers into your circuit i may have mixed something up because i could not get any sound other than a crackle in the speaker.Maybe i need to use a different speaker?. I would really like to get one of these things to work because it would be quite amusing for awhile lol. If i take a picture of the circuit without the potentiometers added would you be able to help identify if i made an error during the build?.I also think that i have used the correct capacitors as well..the capacitors that you used that are stamped "104" would that be 104k?.The other capacitor is 100uf and is 10v?. Thanks,
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:TXTCLA55(Simple Circuits By: TXTCLA55)
Hack, build, design, and create.
