CHEERS!
Remove these ads by
Signing UpStep 1: Gather the Materials
1.) A scratched CD
2.) White toothpaste (not the gel kind)
3.) Warm water
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Many interesting posts some of which (the failures) point up a basic problem and that is a lack of specificity as to the "grit" size(s) required. Brasso and/or Crest, tooth paste vs. "gels" are different ways of -- implicitly -- indicating grit sizes. What we collectively need is some guidance as to what grits to use to achieve what results. With numbers, one could go to an industrial supply store and buy the appropriate powders (probably a range of three to five would do fine). I've been sharpening chisels and plane blades for years using a buffing wheel (easily available at Home Despot) and "rouge" sticks (once available at Sears but I haven't bought any new in decades), and with the correct selection of grits and in the correct order, a mirror finish that one can shave with can easily and quickly be put on a chisel or plane blade. I'm not suggesting buffing wheels for CDs and DVDs (although it might actually work fine if done with GREAT CARE), but the principle is the same; we need some numbers, and some suppliers. (Cleaning, the proper buffing motions, etc. all seem to be handled nicely by the existing posts. BTW, I've managed to bring DVDs back long enough to copy using simple old nose grease; Vaseline and WD-40 sound like constructive alternatives that I personally haven't tried yet.)
Toothpaste: The white kind.
Toothgel: The gelly kind.
Toothpowder: The old fashioned kind.
I had to reformat and re-install Windows XP Pro. Set-up could not read the files from my disc. I was bummed! I did the toothpast thing and brasso thing with no success. I read your post about the WD 40. It did stop on me several times but I just kept hitting enter and one time I had to use the WD40 a second time. But it worked like a charm. I am now finishing my OS installation with XP Pro. You are my hero!!!
(removed by author or community request)
the reason why you dont rub in a circular motion, rather, is because it's much easier for a disc reader to read through a single notch of unreadable data, than a continuous, circular stream of unreadable data.
toothpaste doesnt work too well. only looks clean when its still wet, but once it's dry, its back to step one, even if there are less scratches.
the real trick is brasso, and metal polishes.
hint hint
If you respect CD-R's as they are, precision optical media, and handle/store them as such, then you will never have such damage to your media surface.
Pretend it's the '80's, and you are the only one to hold this technology. Do you ignore the sensitivity of it, or do you try to keep it as mint as possible? I *still* have CD's that not only work, but are some of the earliest varieties, since they first came out. They work just fine if you handle properly.
P.s - Very off topic but if you wanna see something cool go here, it's how to turn your pc into a mac without changing anything fancy, only the way it looks, not performance.
http://www.engadget.com/2004/06/09/turn-your-pc-into-a-mac/
