A New Way to Make an Aluminium Alloy Robot
24,604
121
13
Published
Introduction: A New Way to Make an Aluminium Alloy Robot
With modularized mechanical structures, electronic modules, and Arduino programming, I made this aulminium alloy robot with Makeblock. (Now they are on Kickstarter, and many super-value kits are available.
Step 1: Tools
Tools needed: Screw drivers and a plier.
Step 2: Prepare Motors
The tank is two motor drived. So I first need to make two motors possible to be installed onto the beam structure.
First solder the wires and the connectors to the motor.
Then add the motor bracket.
Step 3: Prepare Wheels
Two 90T wheels with shaft connector needs to be installed onto the motors.
Two 90T wheels and  twelve 66T wheels with flange bearing are needed.
Step 4: Prepare All the Neccessary Parts
Beams with different length
Tracks
screws
plates
wheels
motors
tools
Step 5: Make the Frame Structre
Connect two beams with a plate to make a long beam.
Step 6: Install Two Motors
Step 7: Install the Wheels
90T wheels were installed on the end, while the 66T wheels installed in the middle.
Step 8: Fasten Screws
Make sure all the wheels fastened.
Step 9: Add the Track
The track is chainable, so that I can change the length per needed.
Step 10: The Tank Subbase Is Ready
The basic tank is ready. if you add the drivring circuits and a Microcontroller, it is controllable.
Step 11: Prepare the Robot Arm and Hand
I also prepared the robot arm and hand for the tank.
Step 12: Install the Arm
The arm was driven by a geared DC motor with timing belt. The servo can be used to control the robot hand.
Step 13: Prepare the Electronic Moddules
I also prepared the Arduino compatible electronic modules. They can drive 3 DC motors, two servos, and be controllable remotely by infrared controller.
Step 14: Install the Hand and the Electronics
Step 15: Done
I haven't finished the progrmming and test. Once finished, more videos will be posted here. Just keep an eye on it.
Have fun!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    13 Comments
    Wondering where you got your parts from?
    Is there a way to make that into a 3 sided track rather than having it 4 sided?
    WOW. I can see this kind of thing becoming VERY popular in the future.
    Makeblock! very nice!
    Hey,
    what are those blue plastic storage things at the back called? arent there mounting materials available for them?
    Do you have a source I could purchase the tracks from. If they're chainable one shold be able to purchase in varying lengths, correct.
    Makeblock is not selling the tracks seperately for now. Maybe later. Just keep an eye on their website.
    It would be great if you sold individual parts. There are so many things these could be used for but buying as a kit is not practical.
    Hi Lectric,
    Thanks for your comment.
    Maybe later we will provide some individual parts for the advanced makers. But at present, we think a complete kit is better for the beginners.
    So this is a kit you are selling on kickstarter?
    Not exactly, but you can make a similar one with Ultimate Kit.
