A Nicer Saw Handle
Introduction: A Nicer Saw Handle
juts a handle replacement
cause wood it always better!
Step 1: Cuting and Shaping
after you sketch a handle that you like cut it out out of what ever you like (i suggest wood(i used walnut)). than take a knife or a file and shape the handle part of the handle. after your satisfied with the shape start going up the grits,start at about 80 to 100 and go up to 220 or 320
Step 2: Fitting the Handle
cut a slot in the middle of the part that the handle attaches to (i suggest using the saw that you're fitting the handle to ,to get the perfect fit) mark the hole and drill as strait as possible(i don't have a drill press so don't be nervous it's not that hard) dont forget to counter sink the holes so the scroll will go all the way to the other side
Step 3: Scrow and Oil
at this part your handle is pretty much done all you need to do now is to screw the handle and give it a Finnish
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Very nice, good instructable, thanks
    thank you for the comment i will try to change the shape in my next projects
    Sue-denim (author)Reply2017-09-25
    Please don't take this comment as a criticism, I think what you have done is wonderful but the only thing I would point out is the fact that you have copied the same hand shape as the plastic one. whilst working for 15 years in a Victorian Museum I was only allowed to use wooden handled saws, very soon after starting there I noticed that there was one major design change in the hand shape of the handle, I also noticed that I could work with a saw for prolonged periods without getting cramping in my hand.
    The basic shape that fits in your palm is still the same and has not altered in generations but the hole where your fingers go is now convex not concave as all older wooden saws used to be.
    Compare This. .
    A saw isn't a saw unless it has a wood handle. Well done
