A Non-Spinning Circular Wing Paper Glider
 by ImageMaker
This is a paper glider I learned to make long ago (roughly 1970); unlike other circular wing paper gliders, this one requires only a single sheet of square paper (I'll show you how to make regular printer paper square, too), no glue, tape, or staples, no adjustment, and no special launching technique to impart stabilizing spin.
Step 1: Start Here
The folding starts with a square sheet of paper, but unless you're an origami aficionado, you probably only have the ordinary rectangular sort around.  No problem; you can easily make any sheet of paper into a square sheet accurately enough for this build.  This works best with 8 1/2" x 11" or A4 printer paper, but I've made these gliders out of note pad sheets as small as 4" square (after squaring up) and as large as tabloid (11" x 17" or A1); the smaller ones don't glide as well (too heavy, because the paper thickness doesn't scale with the sheet size) and the larger ones are fragile (again, paper thickness doesn't scale, so you wind up with thinner paper relative to the forces of handling and flight), but with care, they do work.
To demonstrate squaring the paper, I've started with a common letter size sheet.
OrigamiAirEnforcer says: Jul 1, 2012. 3:35 PM
Quite well written and photographed for a first instructable.
Wonderful! :)
ImageMaker (author) in reply to OrigamiAirEnforcerJul 1, 2012. 5:52 PM
Thanks! :)
OrigamiAirEnforcer in reply to ImageMakerJul 1, 2012. 10:30 PM
Just to point it out, I believe the official term for a wing of this shape is "annular". :P
ImageMaker (author) in reply to OrigamiAirEnforcerJul 7, 2012. 8:00 PM
You're correct -- but more of my readers will understand "circular" than "annular", and the photos make it completely unambiguous.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
