A Pallet = a Bench
10,365
304
12
Posted in WorkshopPallets
Introduction: A Pallet = a Bench
About: up-cycling designer micro-normal-macro size
The conversion of a EUR pallet into a bench is a simple operation, will cost you less of a euro and relatively short time . Conditions to achieve an ergonomic sitting are linked to its size. This instructable will help you to build a resistant, light, ergonomic, recycled, outdoors, easy assemble, cheap and lovely furniture.
Material
  • 1 EUR Pallet
  • 14 screws size 5mm X 100 mm large head
Material
  • Hand Saw
  • Impact Driver
  • Crowbar
  • Sander (if needed)
Step 1: The Pallet EPAL
First of all you need to find this type of pallet.
To check standard sizes of EUR-Pallets follow the link below
http://www.epal-pallets.de/uk/produkte/vergleich.php
Step 2: First Cut
First cut : follow the red line as shown
  • Along the short side
  • Only the top layer
  • Just on the edge of the middle blocks
Step 3: Second Cut
Second cut : follow the red line as shown
  • Only the bottom layer,
  • Just on the edge of the middle blocks, opposite of the first cut.
Step 4: Pull Apart
With a crowbar pull apart the elements marked with a red line.
  • The three blocks nailed to the top layer
  • The three bottom planks that are nailed to the middle blocks
  • Proceed carefully to avoid eventual cracks in the planks
Step 5: Inserting Backrest Elements
Insert the blocks between the planks as pictured
  • Spread apart slightly the planks of the bigger segment
  • Slide between those planks the blocks of the smaller segment
  • Verify that blocks have been entirely inserted
Step 6: Fastening Backrest Element
To fasten the elements together, insert the screws as pictured
  • 5 screws @ top planks
  • 3 screws @ back planks
Even if the backrest planks already has a fixation points, due to the structural nails, those extra screws grants the strength for extra load on the bench.
Step 7: Fastening Elevation Elements
To fasten the elevation elements , insert 2 screws each as showed on the picture.
  • For a stronger connection, insert the screws from the planks side into each of the blocks
  • To adjust the ergonomics, slide the elevation components to the front or to the back before fasten by screws
Step 8: Finishing
The conceptual frame is clear and sufficient to play with proportions and adjustments.
I would like to suggest few more variants for the same prototype
  • Remove the middle elevation element and relative bottom plank
  • Sanding it is friendly to public and rain resistant
  • Become more stable and 4 support points are enough
  • Reuse those parts for new functionality
  • Different possibility
    • armbands
    • extra elevation
    • different angel
    • glass holders
    • and more
thanks for you time & hope you enjoy
redeemade
2 People Made This Project!
  • Casting Contest
    Casting Contest
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
12 Comments
grazie grazie ..
Stefania ha fatto una campagna di Pubbliche Relazioni degna da EXPO.
prossimamente a milano
Grazie
e´ anche per la vostra generosa provvigione di materia prima per sperimentare.
A presto all´EXPO.
