iImage Information
I use a LOT of twisted wire in my art. So looking about for good ideas on different things I could do, I noticed there was no instructable (at least that I could find) for twisting wire. Even with all the really great instructables available on the site, I still couldn't find one. Of course this doesn't mean there isn't one, but I thought I might share this little secret on how to twist wire easily, and get the perfect twist. I have seen a lot of people trying to twist wire by hand, and having a hard time just to get inferior results, and I have seen "manual wire twisting" gadgets that cost a fortune. But why spend anymore than what you absolutely have to, especially when the easiest way to twist a perfect wire is by using things you probably already have around the house.
For this instructable you will need:
Wire cutters to cut the wire
Wire - any pretty much any guage can be used determined on what you need the twisted wire for
A phillips head screw driver, the longer the better so you can hold onto it while twisting
A power drill ( I personally prefer to use my hubby's cordless, just because there is no cord to deal with and I don't have to find a place to plug it in)
And even though I didn't mention it, or put them in the photo, you really should protect your eyes!
Step 1Cut the wire and fold it in half
iImage Information
Remember you will need more than twice the length of wire you would require for a single wire peice. You will be doubling the wire over, and you will lose a certain amount of wire in the process of twisting. I don't recommend twisting more than the length you can stretch your arm to hold (see the photo as an illustation). You can twist a longer amount if you have someone or something to hold the opposite end, but since I generally have no volunteers when it comes to working around me and power tools, I stick to the shorter lengths and make do as I can.
I cut a 20 inch piece of wire for this project, and after twisting and trimming I had a 5 inch piece left. This will vary for the guage of wire and the amount of twisting applied.
I started out playing with solder when I was very very young I would sit on the floor of the garage while my dad worked on things, and I would take the scrap solder and make rings and other jewelry. Makes me wonder what I did to my brain cells back then! All that lead, probably some acid core solder? I might have been a true genius had I not done that LOL! Or maybe not. But thanks for the compliment. I have been trying to get back on here to do some more instructables, but my father has been seriously ill so I end up spending more time in the hospital than in the shop. But I shall return! eventually.....
make two piceses of twisted wires same length going in the same direction
put both wires in the drill and spin in oposite direction
it gives a very interesting pattern
It was so awesome.
A small, inexpensive hand operated rolling mill (from Harbor Freight) has allowed me to flatten some of these wires and twists into ribbons or tinsels. Soldering the ends together before twisting can be of great help. In fact soldering the materials along their full lengths can be a help for some effects. Any separation of solder during rolling will quickly repair during annealing.
You may want to experiment with combinations of wires (copper/ brass/ silver etc.) if you want mixed metal twists. Anneal your wire/ribbon OFTEN to avoid metal fatigue and failure.
I also incorporate strands of thread, floss, and feather and fur into some of these twists for decorative purposes. These materials are NOT durable for much milling or any heat, but can add stunning accents and textures to items. submark
Anyhow I am VERY photo challenged. When I sold my SLR to a friend in the '80s it still had film in it from my days in the Navy in the early 70's. Not much of a snaphound.
Check out makersgallery/goss/rollprint for some kickass techniques.
I can't find my little rollpress and Harbor Freight doesn't carry them anymore. If you're really serious about non ferrous metalwork, try to find a used one. They are necessary for serious and quality work.
Cool way of doing it though!
what manner of wire art do you do?
I have used everything from 14 ga to 24 ga wire in a drill to twist it, and they all seem to work well.
Do you do wire art? I would love to see what you are doing.
myself not so much, at least not with such thin gauge wire..
i've found myself rather into chain maille recently, in fact i'm currently working on a full length shirt. i've also done a number of bracelets and other such jewelery.
thanks.
