Materials:
Metal tool box (18'x8'x9' or larger)
300 watt Samlex pure sine wave inverter (Frys.com $130)
(I have been told that Samlex's new 300 watt inverter with usb will not work with a power box. Based on Samlex's new design, a 600 watt inverter is needed to run just one 300 watt strobe. There must be other pure sine inverter alternatives out there, that people can recommend)
Scooter/wheelchair battery 26AH-35AH ($40-$100)
40 amp Square D Breaker QO (single pole AC/DC breaker $14 electrical supply store)
8 AWG Braided Electrical Cable (SOOW 8GA $12)
Bolts and lock washers
(2) Brass washers
(2) 2 1/2' and 3' angle brackets
Ground Fault Circuit Interrupter (GFCI) and Box Housing ($16+$5 Home Depot)
Old scrap extension cord with plug
Large nail or spike
Hose clamp
Zip ties
Flat piece of hard plastic
Copper ground wire stripped from an electrical cable
Battery clamps
SAFETY: Disconnect the battery when working on the circuit. Wear gloves when handling the battery.
Remove these ads by
Signing UpStep 1Angle Brackets
Mark and drill holes for the angle brackets. Remove the paint from under the left 3" bracket. This bracket will attach to the ground spike. 2 1/2 " brackets were used on one side because the box was not wide enough for 3 inch.
Mark and drill holes for the inverter and the inverter ground bolt. Remove any paint from around the holes so there is a good electrical contact.
whish elinchroms you use?
I have 2 - 500ws BXri. Do you think it will work ok with my strobes as they are a digital model?
Is your DIY portable power pack still working ok after all this time?
Best regards
Miguel
Three months ago I loaned the pack to someone and they burnt out the inverter by shooting too quickly with a 1000 watt load. The design of Samlex inverters have been changed so they now shut down with a low voltage. I haven't found a decent replacement inverter locally to rebuild it with. I guess in Portugal another option might be the Paul Buff vagabond mini, if you have the cash. http://paulcbuff.eu.com/cms/
25 amps for less than a foot= 12 guage flexable wire is fine.
I use #10 on my 400 watt inverter system.
GFCI- GROUND fault circuit interrupter.
The inverter is poorly grounded if at all, the best thing to do is not get electrocuted.
I learned that the hard way!
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=wheelchair+battery&_sacat=See-All-Categories
